April 2025
6 7 8 9 10 11 12
13 14 15 16 17 18 19
20 21 22 23 24 25 26
27 28 29 30
Like Tree163Likes
  #161 (permalink)
Old 07-20-2017, 03:24 PM
cobrakiwi's Avatar
Cobra Make, Engine: Coombe, Shelby Block 496
Next up, foot boxes and firewall, installed the insulation and the fresh air flapper.
Then installed them in the car for the final time hopefully,
Got the go pedal installed and the firewall panels.
Things are going together nicely!.
jehammer1952 likes this.
  #162 (permalink)
Old 07-21-2017, 07:13 PM
cobrakiwi's Avatar
Next up is the diff, rebuilt the unit with a 3.54 gear.
Welded the baffles on the cover to keep the oil where it should be,
Install the top mounts, I still need to make the front mount then install.
  #163 (permalink)
Old 07-23-2017, 01:43 PM
cobrakiwi's Avatar
Headlight buckets and side vent grills installed
  #164 (permalink)
Old 07-23-2017, 04:14 PM
LMH's Avatar
LMH LMH is offline
Nice! Glad to see the vent louvers painted. Just don't see that on many yet it's how they were.
Alba gu bràth
  #165 (permalink)
Old 08-01-2017, 03:06 PM
cobrakiwi's Avatar
Today's task was making up diff mounts, all done and off to be powder coated.
  #166 (permalink)
Old 08-01-2017, 06:15 PM
1795's Avatar
Nice work Craig. They look great.
  #167 (permalink)
Old 08-02-2017, 02:09 PM
cobrakiwi's Avatar
Thanks Jim, (your engine startup video was great!)
Today I got the oil cooler and shroud installed.
Then the radiator was installed.
I had special help today from my young 11 year old son, he helped install the rivets around the front edge of the hood,
Mongoose930, 1795 and jehammer1952 like this.
  #168 (permalink)
Old 08-03-2017, 02:59 PM
cobrakiwi's Avatar
More aluminum work today, got the trunk just about all finished, just need to make the diff access panel up.
Also installed the twin pusher fan motors,
1985 CCX and jehammer1952 like this.
  #169 (permalink)
Old 08-03-2017, 03:36 PM
1795's Avatar
Looking fantastic Craig. Your son did a nice job with those rivets, must be genetic...
  #170 (permalink)
Old 08-04-2017, 11:44 AM
Looking fantastic! So what's the secret to fastening rivets on painted surfaces without boogering up the finish or cracking it? I highly doubt we are looking at the faux rivets that you see on other replicas.
  #171 (permalink)
Old 08-04-2017, 02:13 PM
cobrakiwi's Avatar
The rivets are real
it's a nervous job for sure
I use a aluminum shank rivet and a tool I made on the back side of the hood panel so the rivet won't pull the hood skin down.
My help (son) holds the tool on the back side of hood while I pop the rivets.
I also pull up on the rivet gun as I do this so it puts minimum pressure on the paint surface.
Seems to work well for me thus far
ACademic likes this.
  #172 (permalink)
Old 08-10-2017, 03:36 AM
cobrakiwi's Avatar
Diff mounts back from powder coating, looking pretty
This wraps up the rear end, just need to add oil.
  #173 (permalink)
Old 08-11-2017, 03:34 PM
cobrakiwi's Avatar
Covered the rear bulkhead panel and inner rear fenders.
Got them installed,
  #174 (permalink)
Old 08-12-2017, 05:19 PM
cobrakiwi's Avatar
Roll bar installed.
  #175 (permalink)
Old 08-16-2017, 04:02 PM
cobrakiwi's Avatar
A little more progress, carpet in
  #176 (permalink)
Old 08-19-2017, 05:39 AM
cobrakiwi's Avatar
It was a busy week gone by, lots of parts added to this build.
Just about ready to start the fuel system and wiring.
Windscreen mounted along with the hood latches / handles etc.
  #177 (permalink)
Old 08-21-2017, 09:57 AM
cobrakiwi's Avatar
Just about have the Dash ready to go and started in on the fuel tank.
This car is getting one of our large comp tanks.
  #178 (permalink)
Old 08-21-2017, 01:02 PM
All this stunning authenticity and no fuel pressure gauge? With the comp tank option no need for that middle one, true? Plus they're rarely accurate except on two readings...full and empty.
cobrakiwi likes this.
  #179 (permalink)
Old 08-21-2017, 04:18 PM
cobrakiwi's Avatar
The customer and I had a discussion regarding the fuel level gauge over a pressure gauge. He has no use for the pressure gauge and wants the level gauge, so the level gauge it is.
I really don't have a problem with it, not that big of a deal and easy to swap out if he changes his mind down the road.
I have great customers and I try to build them the car they envision and want.
Now if my customer wants a 6 inch lift with big mud tires etc, then we would have a little problem.
Come to think about it, no we wouldn't have a problem because I would not be building it.
  #180 (permalink)
Old 08-26-2017, 04:34 AM
cobrakiwi's Avatar
Started in on the wiring, mounting the items needed to make the whole thing work as it should.
Not the most exciting part of the build but an important part.
