1 |
5 |
8 |
12 |
15 |
19 |
22 |
26 |
29 |
30 |
31 |
3Likes
02-09-2008, 09:12 PM
Patrick
I am a serial lurker (well thats what my mom used to say anyway or was that shurker) on your site. I am building a Cobra (slowly).
I can not add anything to what you are doing other than to say simply AWESOME.
I cant wait for you to do the dash.
Bruce
02-09-2008, 09:43 PM
TX
Man that is just talent.
I have looked at this thread for awhile now. All I can say is wow!
Congrats on having the skill to do all you have on your own.
Looking good!
02-10-2008, 06:38 PM
Mi
Cobra Make, Engine: Scratch building frame,FFR Mkll body ,302w, and T5 trans, 3.0 rear.
I'd love to post some pics on this (my build) site but haven't figired how yet.
1963 Mercury Monterey 460+ .060 .//Cobra clone, Scratch build frame /302/ T-5 WC / 3.00-9in/FFR mkll body (Broken but repairable) /91 Lincoln Wire Wheels // : N.S.M.C Charter/Life Member// Die Hard Blue Oval Nut
The finish is better than the beginning. Ecc7:8
02-10-2008, 06:43 PM
LA
Cobra Make, Engine: Joey Manufacturing Inc.
carl, I use Image hosting, free photo sharing & video sharing at Photobucket, just upload your pictures there and then get the image code and paste it in your post. the image codes look like this:
[IMG]the code[/IMG]
"Me fodder was King Neptune, me mudder was a mermaid. I was born on the crest of a wave and rocked in the cradle of the deep. Me hair is like hemp, me arms are like spars. When I spits, I spits tar. I'm hard, I am, I is, I are. "
02-24-2008, 04:01 PM
mn
Cobra Make, Engine: scratch build self design 4.6l DOHC
Spy Photo's
Hey guys,
I've been busy lately trying out some new things. just a peek at what will be the dash / tunnel cover for the scratch build. now I could never have a stock dash in this car. So as per usual I'm going overboard with a one piece unit that will house all the gauges, switches and whatnot. It is still in it's crude form(lots of sanding required), then I can pull a mold of it to make the final part. I'm still on the fence if I should cover it or paint it to match the car.
Patrick
02-25-2008, 04:33 AM
MD
Cobra Make, Engine: Unique 427 S/C 427 FE S.O. 484 cu in
I'd paint it to match the car.
How is it going to be to work on the wiring and if you need to replace a gauge when the car is complete with it being all one piece?
02-25-2008, 06:52 AM
PA
Cobra Make, Engine: Myself/Body from CSX-2575 & hand built Birdcage
It's going to have cracks from the chassis flex painting would be a mistake..
Mike
6S1941
Allied 289 Slab Side
73 2.3 turbo pinto
02-25-2008, 06:53 AM
LA
Prolly have an access panel on the firewall???
I second the painting it to match the car. or maybe faux carbon fiber?
02-25-2008, 07:18 AM
LA
Mike
Patrick's chassis will flex..after the M1 Abrams flexes.
02-25-2008, 08:58 AM
PA
If it ain't have a 14 point cage it will bend.
Hang everything on the car jack it up at the CG and see what happens..
6S1941
73 2.3 turbo pinto
02-25-2008, 09:05 PM
mn
Flex! could happen, like I said on the fence. I plan to be able to pull the whole unit out of the car rather easily. Very few bolts and some rubber mounts in places. Pop off the shifter and brake boots, drop the column and lift, pull and out it comes with one or two large multi pin harness plugs,(my best friend is an electrical engineer parts are not a problem) ah the beauty of electric gauges. Besides I need it to do so to allow for the tranny removal. The seats will lock to the floor (ala minivan style) in multiple positions for different drivers, and quick removal. Yes everything about this car is just a little different.
Patrick
03-02-2008, 09:28 PM
mn
sand and sand and sand some more
After a bunch of sanding I am close to final on the dash plug some small holes to fill and edges to finish and I should be able to paint and start waxing the f___ out of it. I just hope that the body isn't this hard to work on.
The rings are for the gauge placement, shifter location, and sanding guides the incomplete ring is where the column goes.
Patrick
03-02-2008, 10:42 PM
Banned
CA
The things that I could do with 10% of your crafting skills...I have really enjoyed watching this build. Thanks for sharing with us.
-Dean
03-03-2008, 03:33 AM
Hi Patrick
Sure done a lot of sanding. Looks sort of womanly.
Thoughts
Have you looked at using a couple of sheets of carbon fibre over some areas of the dash. I dont know what sort of look you are after but carbon fibre sheet can be layed over the fibre glass fairly easily.
Did you think about turning the gauges slightly towards the driver so the viewing angle is easier.
Bruce
03-03-2008, 08:07 AM
LA
P,
Here is a picture of a helmet I am working on, it is the prototype so I used faux carbon fiber on it. As you can see it looks very real. Here is the link where you can get the FCF if you decide to go that route, I think it would look saaweeet!: Sign Supplies and Equipment: Avery Carbon Fiber - 15 inch x 10 yds Perf - Black - Low Price Guarantee
03-03-2008, 07:45 PM
mn
More car porn
Alright I'm only typing this reply once and posting it around, so here's the answers.
Never even thought about the womanly shape, weird. Yes the large gauges are angled slightly toward the driver. Not really a big fan of the carbon fiber look, would love to stretch some fine leather over it. but will probably just cover with something to coordinate with the seats when the are redone. The mold will be three pieces and will have to be done in the car. The plug is built up on the chassis so it will be destroyed after I have molded one from the molds( when I have made the final piece I would like to see if it would fit other cobras as well).
Here's a pic with the fake gauges and seats in the car there is not a lot of space for access so the seats will pop out and the whole piece will lift out and unplug for maintenance.
Patrick
03-05-2008, 07:04 PM
Banned
CA
Is there a provision (room) for a parking brake handle? Looks tight.
Any thoughts to more symmetry with the smaller gauges (i.e. 4 in-line and below the tach/speedo and centered). Or were you looking for something a little different? Where are you planning to mount the ignition and toggle switches for cooling fans, heater/defroster blower, nitrous arming, line lock (maybe that answers the previous parking brake question) or whatever needs a switch? Any warning lights planned for the dash (i.e. alternator, brakes, etc.)?
I've been giving you "A" scores so far, but the more I look at that dash layout I start to write down "B-".
03-05-2008, 08:31 PM
mn
Parking brake is center between seats(see photos in gallery, ignition is in the column, indicator lights will all be LED type above column, light switch will be to left of column, other switches will be below the gauges, don't need many, power outlet(ie lighter socket with billet cap) will be to right of small gauges. may try to fit in a I-Pod dock on passenger side. Sorry there is not going to be a lot of do-dads added to this car, I've always liked the minimalist approach, although machine guns in the air ducts would be useful.
Patrick
03-05-2008, 08:39 PM
TX
Or the ejector passenger seat so the FIRST time she whines about the ride being rough or the car being smelly,
WWWOOOOOOOOSSSSHHH!!! See ya later!!
MadMiles442
03-12-2008, 12:30 PM
Md
Cobra Make, Engine: scratch built (in process) 4.6 2v mustang
finally back
Patrick, everything is looking very,very niceeeee havent been here in a while-- job change--new toy(birthday present from my wife see my photo gallery) waiting for warmer weather to get back on the cobra. keep up the awesome work
later
Den
