-   Shelby American, Inc. (http://www.clubcobra.com/forums/shelby-american-inc/)
-   -   Clutch/brake fluid (http://www.clubcobra.com/forums/shelby-american-inc/124353-clutch-brake-fluid.html)
ray humbel 12-02-2013 10:57 PM
Clutch/brake fluid
What is the best clutch / brake hydraulic fluid for use in a CSX4000?
Tommy 12-03-2013 03:50 AM
How do you use your car? Any track time? What's in it now?
ray humbel 01-03-2014 07:52 PM
Fluid
Whatever was in it when built . All street use
Tommy 01-04-2014 04:45 AM
Ray,
You'll need to check with the builder to see if it was DOT 5 fluid. If so, you'll want to continue using it. If it was DOT 3 or 4, you can use either of those. DOT 3 is fine for street use. DOT 4 is better for track use as it stands up better to higher temperatures generated by heavily used brakes. I use ATE brand DOT 4 fluid.
