Go Back   Club Cobra > Manufacturers, Engine Builders, tools, and parts. > Shelby American, Inc.
April 2025
6 7 8 9 10 11 12
13 14 15 16 17 18 19
20 21 22 23 24 25 26
27 28 29 30
Old 02-23-2014, 02:46 PM
mikyFIA's Avatar
Cobra Make, Engine: SAI 331 Shelby Engine with Webers
Default Webers on a 289 from Shelby Engine
I am wondering if anyone here has a Shelby Engine 331 289 with Webers on it. I am considering that for my build. Thanks for any insights.
Old 02-23-2014, 04:16 PM
CC Member / Sponsor
The coupe I was running at SAAC in Fontana had a 331 with Webers. One of the best engines I have ever driven. Loved it.
Cubic Performance
HiTech Legends
https:HiTechLegends.com
Evolve Lubricants
https://evolvelube.com/
Old 02-23-2014, 04:24 PM
Bill D's Avatar
Cobra Make, Engine: FFR chassis and suspension, Mr. Bruce 289 FIA body
My 331 in my GT40 had 48IDA Webers. Ran like a raped ape
Old 02-24-2014, 06:30 AM
mikyFIA's Avatar
Thanks guys, now let me ask a further question. Is it possible for Shelby Engines to set up a Weber system on the 331 that is reliable, dependable, and doesn't need a Weber tuner in residence to enjoy driving in other than racing conditions?
Old 02-24-2014, 08:34 AM
dallas_'s Avatar
Miky, not sure where you are located, but Jim Inglese (separate from Inglese Induction Systems) is a great resource for Webers in Cobras. Home
Reach out to him, he can answer all your Weber questions.
My Webers are on a 427w so it's similar but different from your setup.
Old 02-24-2014, 08:54 AM
mikyFIA's Avatar
Thanks dallas, I have talked to him, and am just trying to figure out who to get to build and set the Webers up. I know he comes highly recommended, so leaning that way when it is time. But, has anyone used Shelby Engine to do this?
Old 02-24-2014, 10:04 AM
1985 CCX's Avatar
Mine is a 289 0.10 over..........
48IDA via Inglese, did not want to rebuild Italian carbs
Old 02-24-2014, 11:31 AM
mikyFIA's Avatar
Thanks, I also definitely want modern Webers, not the original old style ones.
Old 02-24-2014, 09:08 PM
Earl J's Avatar
Cobra Make, Engine: GT350,289 w/48IDA Webers
Send a message via AIM to Earl J
I run a 289 +.030 (292 and change) with an Original set of Italian 48 IDA’s circa 1964-65 (not IDA-1’s or IDA-4’s)carrying serial numbers; 983, 985, 1031 & 1035. A true early set. Mine are not drilled for the 3rd progression holes and they do have the screw down type accelerator pump jet nozzles, not the modern push-in type. No issues. I drive this car regularly (it is a GT350 not a Cobra) This motor is still in the car. I did consult with Jim Inglese 4-5 years ago for a base line for jetting but I have since modified it accordingly. I did this past year build a new engine; an 8.2 deck 4 bolt main block, steel 3.25 stroke big bore (I won’t call it a 331 though) which was designed for these Webers. I have yet to install and run it. The 289 on the other hand is still fairly running strong and trouble free (tuning wise). So we’ll see possibly later this spring for an engine swap.
Earl J
Earl J Castillo
VP NorCal Region SAAC 2012
Old 02-25-2014, 12:03 AM
xb-60's Avatar
Originally Posted by Earl J View Post
Nice looking setup Earl.
Glen
Old 02-25-2014, 05:25 AM
1985 CCX's Avatar
Earl
They look awesome...........
I went with a known set versus the option of rebuilding a set from the 60's. If all was the same I would go Italian early, but all is not the same so I chose the high road..........
Old 02-25-2014, 06:34 AM
mikyFIA's Avatar
Thanks guys, good info and insights here.
Old 02-25-2014, 08:04 AM
dallas_'s Avatar
We do love our Webers!
Old 02-25-2014, 08:30 AM
Earl J's Avatar
The only differences between new/modern 48 IDA’s and early that I can see are:
Early EW carbs up to “48 IDA-4” but not including do not have the triangle “V” bosses (for linkage?) on the outside of the bodies. The earlier carbs will also have serial numbers instead of date codes. I will not include the pre-48 IDA carbs known as the IDM which were also 48’s.
Internally, the EW IDA, IDA-1 and IDA-4 have the screw down jet pump nozzles with the check ball in the hold down screws themselves. I may be wrong on the IDA-4 which started production in the late 60’s early 70’s. There was a transition period where minor details changed, most notably the exterior vertical mounting bosses for linkage (I’m guessing) V8 applications don’t use them. All these 48 IDA’s came with two progression holes.
Modern IDA’s the ones from vendors like: EMPI, Redline and others or either cast “made in (blank)”, the ones from Spain, and back to Italy or South America and China (more currently) are pretty much the same design. The details I’ve seen are the push on jet nozzles that take the rubber “o” rings and more currently the 3 progression holes. Machine screws are used (on modern) instead of studs and nuts found on early body and air horn attachment methods. That’s about it.
Construction quality on modern units is an unknown to me. So just be careful and be VERY selective if you’re buying used pieces. (Other people’s frustrations) Also check the number of progression holes between ALL the carbs.
The bad thing about buying used is; I wouldn’t trust the jetting in them as some previous owners modified them (soldered and or drilled out) so what they read may not necessarily be what they are. Just so you know what “stock” 48 IDA’s came jetted brand new out of the box (at least early originals):
37mm venturi
4.5 Aux Venturi
135 Main Jet
F7 E-tube
120 air corrector
120 Idle jet holder
70F10 Idle Jet
50 Pump Jet Nozzle
50 Bypass Jet
25.5 Float
200 Needle Valve
I would talk with Jim Inglese as noted earlier for a base line jetting based on your car specs. Jim will ask. If he does set you up MAKE SURE you ask him what size he drilled or modified a particular jet to. As he will grind off the size leaving you clueless.
Lastly read Tennessee Tim’s Weber Tuning Tutorial posting here on the CC forum. It is one of the most informative writing pieces available anywhere. It’s currently free. It’s better than most books out there.
Have fun.
~Earl J
Earl J Castillo
Old 02-25-2014, 10:29 AM
mikyFIA's Avatar
Thank you! Very complete and descriptive for a novice like me. One additional complication, that I have talked to Jim about, is that I live near 7000' and much of my driving will be from there up to 10,000' or so, as we have some great mountain roads around here for rallies, cruises, etc. He indicates the jetting would be critical for this situation, and a special item to focus on.
Here is a picture of what is being suggested.
Old 02-25-2014, 11:04 AM
Earl J's Avatar
It's nice looking. Looks like Joe at Denbeste Motorsports has built you up an all aluminum 331 with Webers. Careful, the intake valve size on those heads are 2.08 and with a port volume of 205cc, unless you specified differently. If that is your motor, you’ll have to adjust tune it to your altitude.
Best,
Earl J
Earl J Castillo
Old 02-25-2014, 01:32 PM
mikyFIA's Avatar
You're right all around. I will probably need to understand these Webers as well as I understand my '68 Holley 9510 carbs.
Old 02-25-2014, 03:02 PM
legenmetals's Avatar
Cobra Make, Engine: contemporary(2) one with 427 sohc and one with 427 center oiler
Default 260 c.i. webers
Insert Photos and Images
My 48 IDA webers from Jim Inglese. Jim had to custom make the 34 mm chokes for the 260 c.i. size. Jim supplied the complete Intake set up.
Valley Head Service did the porting and installed the larger valves.
Bullet Racing Cams made the roller camshaft- intake lift .3283 duration @ .50 223, Exhaust lift .3283, duration 227 lobe seperation is 110, Jim said that the lobe seperation will work fine. I hope that I won't have blow back into the carbs. Maybe 112-114 seperation would work better.
Crower roller rockers and Racetec pistons
