CSX6000 Electric Fans
Can someone advise which fuse(s) controls the electric fans? Today I noticed neither my dual fans or my rear electric puller fan is coming on. This is something new. The only work I’ve done was run a new speedo cable so I’m concerned I pinched a wire or unhooked something accidentally under the dash maybe.. Even the manual fan switch won’t activate them like it usually would. I check the switch by hooking up another switch but they still wouldn’t activate.
Also does the puller fan run all the time or based on temp? Thanks for any help. |
For those interested the 2 fuses that control the fans are the 1st and 2nd fuses ( 25amp and 30 amp) from the top on the left column. Also, the top right relay above the fuses also controls both fans.
