12-29-2004, 02:27 AM
NV
Cobra Make, Engine: 427 SC
It is installed on a 1/4" stud on the rear section of the driver side frame rail. If you jack the rear of the car up, crawl under, then look next to the inner rollbar mount, you'll see it. It is screwed into the rear brake junction block and has two wires connected to it with female bullets .
See it in this photo??:
kris kincaid
