Go Back   Club Cobra > Manufacturers, Engine Builders, tools, and parts. > Shell Valley Companies
April 2025
6 7 8 9 10 11 12
13 14 15 16 17 18 19
20 21 22 23 24 25 26
27 28 29 30
Old 08-26-2020, 07:04 PM
Cobra Make, Engine: Shell Valley 428CJ with 427 Tunnel Port top side
Default How to adjust SVC door
The driver side door on my SVC 2005 kit hangs just a little low at the rear. If I lift it slightly as I close it then it clicks fine and is correctly aligned with the body. I have no idea where to start to fix this: adjusting the door on the hinges or the hinges on the body, and the assembly manual is no longer available. Can anyone tell me where the adjustment points are? I would expect that somewhere there are bolts in slotted holes that allow for adjustment. I’d really like to know where I should start to be able to rotate the rear of the door upwards to engage the latch before I start loosening anything and possibly make the alignment worse instead of better.
Old 08-26-2020, 09:09 PM
Cobra Make, Engine: Shell Valley, 351W
The holes in the hinges where they bolt on to the door are slotted. You can loosen those up a bit and move the door around.
Old 08-27-2020, 09:13 AM
Cobra Make, Engine: shellvalley 428 ford
I would suggest you call Dana at SVC 1-888-246-0900.
He is a great guy and very helpful
Byron
Old 09-27-2020, 07:29 AM
Thanks. After further investigation I can see that there is no adjustment on the frame side of the hinge as it’s a pin that fits in a bracket welded to the frame, so I’ll see if I can make the minor adjustment to the doors. It seems the easiest thing to do would be to just close the door and loosen the bolts, hold the door tight and retighten the bolts so that it aligns better,because the fit is very close when it’s closed, possibly just a tiny bit low since the pressure has worn off the weatherstripping.
Tags
shell valley door
Rate This Thread:
