SUPPORT OUR SPONSOR
January 2025
26 27 28 29 30 31
Old 04-10-2010, 11:43 AM
Cobra Make, Engine: Unique
Default brake pedal
started to get the cobra ready for the season and noticed my brake pedal travel longer than usual. went around the block and seems to require much more throw than before... car has been sitting for about ~5mths...
wondering or looking for suggestions...
couple of items:
1) checked the floor for leaks - none
2) checked the master cylinders (both) and fluid is up there at the usual limit
hoping its just either a function of building pressure or brake bleed and not replacement of the cylinder(s).
thanks,
R
Old 04-10-2010, 12:48 PM
CobraEd's Avatar
if u pump it and it comes up, it is an internal leak in the MC.
LIFE IS TOO SHORT TO WORRY ABOUT GOOD GAS MILEAGE
________
Utinam logica falsa tuam philosophiam totam suffodiant!
________
Old 04-10-2010, 01:25 PM
Rick Parker's Avatar
CobraEd is on the money Roscoe, go no further; kit the master cylinder.
Rick
Old 04-10-2010, 02:03 PM
thanks cobra ed...
rick,
going to try it again and see....
thanks,
gino
Old 04-11-2010, 05:56 PM
tried it again today and the same.... pumped several times and pedal did not come up; maybe need to bleed the brakes?
driving me nuts
Old 04-11-2010, 06:58 PM
If you have floating calipers (non-opposing pistons), check that they are not frozen to the brackets.
Old 04-11-2010, 07:20 PM
It's still the master Roscoe, internal leak, bad cup seals. If it were OK you would get a firm pedal after a couple of strokes.
Rick
HTML code is On
