SUPPORT OUR SPONSOR
January 2025
26 27 28 29 30 31
Old 07-20-2011, 08:17 PM
Cobra Make, Engine: CMC,Ford 302
Default Side pipes mounting specs?
I'm in the process of mounting my sidepipes and was wondering , "how close should the mufflers be so as not to blister the fiberglass?" I'm building my own headers so I'd like to get the sidepipes in place then build from there. Any help would be appreciated. Don.
Old 07-21-2011, 09:01 AM
Cobra Make, Engine: SPF 2592, Shelby alum. 527
Just measured mine. The distance between the header pipes and the body opening varies between 3/4" to 1". The mufflers are parallel to the body and about 1-1/4" from the body. I used spacers to get them the same from side to side. Hope this helps.
Rodger
Old 07-21-2011, 10:00 AM
Silverback51's Avatar
Polished stainless steel pipes get hotter than coated steel, so they need to be spaced a little further away from the body.
John Hall
Old 07-21-2011, 09:08 PM
WardL's Avatar
Cobra Make, Engine: SPF #2608, Roush 427SR T-W
My SPF is the same as Rodger’s. Maybe the header is only 7/8” from the fiberglass body as it exits the body before it goes into the larger part of the side pipes. The larger size of the side pipes is 1.25”, just like Rodger’s.
HTML code is On
