SUPPORT OUR SPONSOR
January 2025
26 27 28 29 30 31
Old 11-21-2001, 08:15 PM
Question 9" SVO rear disc /axle clearance info?
My fellow Americans,Happy Thanksgiving. does anyone have any input on the rear disc/svo with moser axles and Strange Eng. spacer?...snugged mine up as it came from SValley and the heads of the studs{back of axle flange} hit the emergency brake center anchor,also,when rotor is placed on it scrapes the dust shield.It seems to me the axle is 50/70 thou. to far inward.Has anyone had to unpress this affair and shim the bearing to gain the clearance for this settup to work? none of my paper work deals with this, it's written like it will all go together without a glitch.I tripple checked my work it's all good......any suggestions?
carlo
Old 11-25-2001, 02:41 PM
kountzecobra's Avatar
I used similar setup, and had to ream out lug holes and use press-in studs because the hex-heads on the supplied lug bolts hit E-brake assembly. A simple job for a machine shop. I do not remember what the Dorman part number of the studs were.
HTML code is On
