SUPPORT OUR SPONSOR
April 2025
6 7 8 9 10 11 12
13 14 15 16 17 18 19
20 21 22 23 24 25 26
27 28 29 30
Old 01-10-2002, 07:10 PM
Default Ideal rearend ratio????????
347 stroked, tremac trany, 430 HP. 17" wheels. What's best??
3:27, 3:55, or 3:73 ???
Opinions please.
Thanks
Richard
Old 01-11-2002, 07:12 AM
Frank Coppola's Avatar
I am no expert on ratios but I will tell you this: I have a 3:50 rear with a C-6 3 speed. At 70 mph I'm running about 3,500 rpm +/- 300. If I had a lower ratio I would probably kill myself as there is no end to the pedal. The fun of driving personally speaking is coming off the line. Doing 160mph in a Cobra with a fiberglass body, no airbags, and manual brakes is an unneccesary risk.
My answer to you is to tailor your ratio to what kind of driving you're going to do. I'm sure there is a way to calucate your RPM's vs. MPH with the tranny and wheels you have, but I can't help you there.
Frank Coppola
___________________________________
"Gunga Galunga... gunga, gunga-galunga."
Old 01-11-2002, 07:32 AM
renaissance man's Avatar
Cobra Make, Engine: SMC Motorcars 289
Send a message via Yahoo to renaissance man
I would have to agree Frank.
I'm no expert either but I'm running a 289 HiPo, 17" wheels and a 4.10 rearend with a 4-Speed Toploader. About 4k rpm at 70 but that's my peak torque from 4000-4500. I just mash on the gas and I'm gone! No down-shifting! But I don't care to do 150mph. I like the off-the-line response not to mention the car sounds like a Nascar winding out!
Co-founder of the Texas Cobra Club.
Dave "Ren Man"
Old 01-11-2002, 10:24 AM
Back in Black's Avatar
Cobra Make, Engine: West Coast. 514 / 6 speed Richmond overdrive
Talking 3.00 diff....for Back in Black
My transmission slated for my West Coast is the Richmond Over Drive (ROD) 6 speed, low first, and way overdrive 6th.
17 inch wheels, low profile z rated Michelins
The WCC's are easily 500+ lbs heavier than your car, and I think this will be fine, since I have a 600+ horsepower motor planned...I suggest strongly the 3.27 gears, or you will be doing the kind of excessive rpms the guys just mentioned. Your cobra is light, and has plenty of pickup with the higher ratio....I want to use 5th gear if needed, on the highway, rather than go to taller gears and use 6th...there is a great advantage to the 6 speed, if you don't mind shifting more often (part of the fun for me)
More gears are better!
Bigger is better!!
Old 01-11-2002, 12:23 PM
flipper35's Avatar
Cobra Make, Engine: Shell Valley, Mopar thingy (small block of course)
Default Taller rear end.
I agree with Back in Black, mine runs about 2000 at 70mph and still runs low 12's in the quarter. But if you do track time and not much highway time, you may want to go shorter.
Old 01-11-2002, 03:01 PM
Cobra Make, Engine: Shell Valley, 514 SVO ... now a 4.6L with an AOD!
www.richmondgear.com
They have a calculator there that tells you what gear you should run for a desired rpm. IE - you tell it you want to turn 3000 rpm @ 70 mph and put in tire diameter and it tells you what gear to run.
I've used it a few times to figure out which gears to run at different dirt tracks for my stock car and it seems to be fairly accurate.
Hope this helps!
-Dana
Old 01-14-2002, 07:48 AM
Dominik's Avatar
hi,
in europe the magazines (and we) clocked from 0 to 62 mph, 0 to 100 mph and 0 to 124 mph (that equals 100 kph, 160 kph and 200 kph).
therefore I geared my car to give me 62 (plus) in 1st gear (2.20:1), 100 in 2nd (1.64:1) and 124 in 3rd (1.34:1) - or something! that resulted in a Muncie M-22 or T-10 CR trans with 275-60-15 tires at 6600 RPM (3.31:1 rear).
for the US I would use a WR trans (4-speed) that you can go quick from the traffic light and cruise easy at 65 mph.
If you are racing check for the maximum speed you can achieve at the longest straight. (probably not more than 140 mph)
dominik
If I don't respond anymore, that's because I can't log in
Old 01-14-2002, 08:04 AM
Cobra Make, Engine: SPF
If you are wanting certain drag times, say, 120mph in the quarter, make sure your gearing doesn't require an unneccessary shift at 112mph, or something along those lines. Or worse yet 118mph!
Bob
Cobra Make, Engine: Unique FIA 351 W
I have a Tremec with a .68 overdrive fifth. Originally the rear was a 3:31, and fifth gear was virtually useless unless the speed was 75+ MPH.
I thought about going to a 3:73, but worried that with a first gear ratio of 3:27, first gear would be too short. Eventually I went to a 3:54 rear, and that has been satisfactory, although still not ideal. At least fifth is more useable now, and I can get into fourth around town.
Tremec makes a replacement cog for fifth at .82. That combined with the 3:54 rear might be the best combo. If more punch off the line is your goal, then go with the 3:73 and leave fifth alone. just don't be surprised if you have to shift out of first at around 40 MPH. good luck - - Allen
HTML code is On
