SUPPORT OUR SPONSOR
April 2025
6 7 8 9 10 11 12
13 14 15 16 17 18 19
20 21 22 23 24 25 26
27 28 29 30
Old 01-14-2002, 05:06 PM
Default Weber IDF carbs
Can someone pleaase confirm what the female thread size is at the fuel inlets. It looks like 1/8" BSPP to me, but I want to be sure before I order the hose fittings.
Andy
Old 01-15-2002, 05:18 AM
Mike I's Avatar
Cobra Make, Engine: E-M Cobra - RCR GT40
Andy,
I'm not sure and I could be wrong, but I think my 48mm IDFs have got #6 AN fittings installed (3/8" pipe?). I can't verify that right now because they're at a friends house being detailed, but as soon as I can check it I'll let you know. For all I know, they may have been modified to accept those fittings.
Mike
Maybe BT Snake can answer that question for you since I bought my setup from him. How about it Hersh?
Old 01-17-2002, 05:40 PM
Mike I - Did you get achance to look at your Webers, the fittings that I intend to use will be 6AN hose to 1/8th BSPP aluminium to replace the brass plugs and 3/8th stubs that come with the carbs. That is if the thread in the carb casting is 1/8th BSPP.
Andy
Old 01-18-2002, 04:35 AM
Mike I's Avatar
Red face Sorry I didn't get right back to you
Andy,
I did some research here at work (I work for an aircraft manufacturer) with an engineer buddy of mine and what I found out is that 1/8" NPT (similar to BSPP?) pipe thread is 27 threads per inch, whereas 1/4 & 3/8 are both 18 tpi. I haven't had a chance yet to go look at what I have on my IDFs, but I believe I do have the fine thread (27 tpi) 1/8" NPT fuel inlets as you have indicated. I will check it out today and let you know for sure.
Mike
BTW Andy, I'll expect to see some pictures of your car and induction system....
The photo I've attached really doesn't help much, but it may give you some idea of what you need to buy.
Old 01-19-2002, 05:06 AM
Mike I's Avatar
Thumbs up
Andy,
I checked the fuel inlets yesterday and they are definitely 1/8" NPT threads.
What engine is in your car? I'd be curious to know the specs of your IDFs, i.e. chokes, air correctors, e-tubes, jets etc...
Mike
Old 01-19-2002, 08:00 PM
Mike I - My car has a 302 with Trickflow heads and a sports a Holley 650DP at present, I have bought 3 IDF's and am waiting for 4th.
The settings I intend to start with are:
36mm chokes
135 main jets
F16 emulsion tubes
175 air correctors
Aux venturi 4.5
Idle jet 60
Accel pump jets 50
Andy
Old 01-19-2002, 10:26 PM
BT SNAKE's Avatar
Cobra Make, Engine: Midstates Cobra, RFGT40
Unhappy
Sorry Mike,
I just now saw this thread. I see that you already got the correct answer.
I want a picture of that unit when it's done please.
Hersh
Old 01-21-2002, 03:57 AM
Mike I's Avatar
Wink Hi Hersh!
I've been holding off on installing the system because my car has been running too darn good with the Holley to mess with it. I'm getting to the point now that I need to take a perfectly operating, simple, fuel efficient, low maintenance induction system and replace it with a hard starting, raw fuel belching, difficult to tune, but oh so pretty Weber setup.....what am I thinking??
I think I already mentioned to you (maybe not) that I'm swapping the carbs over to an Inglese manifold that I had prior to buying your setup and I've had to buy some additional linkage pieces to make it all work. I'm also rerouting my fuel delivery system and changing over the ignition system (why am I doing this, it works okay as it is!! )..... Anyway, I'm probably going to start the mods in a few weeks, I'll let you know how it turns out....
How's your 40 coming along??? Post some pix!!!
Mike
BTW, do you still have that hardtop??
Old 01-21-2002, 07:22 AM
Original Shelby Owner
Andy:
Let me know what kind of success you have with the F16 Emulsion tubes.
Old 01-21-2002, 08:13 AM
Andy,
that`s a good looking piece of metal. Itīs kind of hard to get the good adresses over here, therefore my question: can you name a dealer or two and a justabout price for a whole unit?
Aloys
Old 01-21-2002, 02:30 PM
Cal - My friend has just changed from F11 to F16 emulsion tubes on his 289 following some head porting work. I figured that my engine was fairly similar so it would give me a good start for the first dyno run.
Are any of you Weber guys using rod linkage for the throttle? I am hoping to adapt my present set up from the Holley, by moving the bellcrank along the crossover rod so that the carb pull rod can run down the centre of the carbs and pick up on the Inglese bell crank. I prefer rod linkage overall and have had success with multi DCNF's on other cars. (present set up in photo)
Aloys - I purchased the new intake and Inglese linkage from a dealer in the UK who had bought it from Inglese and never used it. The carbs came from a dealer of Ferrari Dino parts in Essex, he just happened to have three that he'd bought in for a Lancia Stratos, but dosen't normaly stock them.
As far as I am aware Weber intakes and linkages for American V8's are not normaly stocked by any dealers in the UK, but Weber IDF's are available.
I will try and find you a list of dealers and post later.
Andy
Old 01-21-2002, 02:43 PM
Andy:
I will try and post a linkage set up that you might want to consider. It is used on GT-350's. I need to charge up the digital camera.
Old 01-22-2002, 07:29 AM
renaissance man's Avatar
Cobra Make, Engine: SMC Motorcars 289
Send a message via Yahoo to renaissance man
What is the deck clearance to the hood that is needed for a set of these on a 289 or equiv?
Co-founder of the Texas Cobra Club.
Dave "Ren Man"
Old 01-22-2002, 07:37 AM
Dave:
I think much of that depends on the Replica in question. I know that Unique's cars can accept the Weber 48 IDA with either the 289 or the 351W. Remember that the IDF like Andy's are about 1 inch shorter which helps in that department. I know, too, that some of the manufacturer's cars have hood clearance problems when using the IDA with the 351.
Old 01-22-2002, 12:10 PM
Cal - Did you have any luck with the linkage set up?
Andy
Old 07-29-2004, 11:23 AM
Does anyone make a 351w intake for the 48 IDF carbs? I know someone that's looking for one.
HTML code is On
