SUPPORT OUR SPONSOR
March 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
30 31
Like Tree22Likes
  #21 (permalink)
Old 06-02-2021, 09:55 PM
Taking the headers off is probably the best idea and will certainly make wrapping then much easier.
Bruce.huling likes this.
  #22 (permalink)
Old 06-03-2021, 10:22 PM
Cobra Make, Engine: Lone star 351w /408cu.in.
Hey Carl
Took off the header. Will get it welded then hit it with ceramic header paint.
Chasing a water leak now on front near intake manifold. Need to get to store and rent pressure tester so I can be sure.
  #23 (permalink)
Old 06-04-2021, 03:54 PM
Bruce, if its just a minor coolant leak, I'd dump in a tube of AlumaSeal. I've been using it for literally decades with good results. It won't clog the cooling system, is a water pump lubricant and an anti rust. If it doesn't do the trick, you'll be out $5. It will not stop water pump shaft seal leakage or hose issues but is pretty wonderful on little gasket leaks and radiators. My 2¢ worth.
HTML code is On
