SUPPORT OUR SPONSOR
February 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28
  #21 (permalink)
Old 02-24-2002, 01:30 PM
Cobra Make, Engine: Classic Roadsters, Tweaked 351W, T-5Z, CRII Tech Support Team.
Bill,
Much appreciate the info. More options than I imagined. Did bookmark your site, and will be asking you for upgrade suggestions as to combinations similar to above. With 17" wheels, there is definately room for improved braking hardware.
  #22 (permalink)
Old 02-24-2002, 02:21 PM
Tom Wells's Avatar
Jack21,
I bought the BAER units. They were the biggest available at the time. I was already committed to 17" wheels.
The ones I bought have the 13" rotor, came with the PBR calipers and pads (same as the late Mustang Cobra), aluminum hubs and caliper brackets. I also went for the aluminum hats which save somewhere around 6(?) lbs per side over the solid rotors.
The total cost was about $1200.
The hubs reduce the front track by 0.3" per side, 0.6" if I recall correctly.
One of the reasons I went this way was BAER's statement that Bondurant's driving school uses the same front brakes on their Mustangs. I called and asked, and they said they did, and had no particular problems.
Hope this helps,
Tom
PS: If I didn't already have the calipers, I'd be tempted to ask BAER if the Cobra calipers would interchange - you know, the ones that say "COBRA" right on the caliper
  #23 (permalink)
Old 02-24-2002, 07:03 PM
Alan...your project sounds like a blast...keep us posted...
Daytona Ray...I have a similar setup and not entirely happy with the pedal hardness...but I'm trying to see if I have a bleed air problem. Don't have any leaks but I'm using CNC pedals & their 3/4" master piston and am happy with the quality. I haven't shaken out the car yet so I'm not going to change anything until I ID the exact problem. 360 HP w/2.75 in my 9"...also wrong!
scratch
HTML code is On
