SUPPORT OUR SPONSOR
January 2025
26 27 28 29 30 31
Old 03-24-2002, 10:25 PM
Cobra Make, Engine: Contemporary 427
Default Contemporary Clutch Slave Cylinder
OK all you Contemporary "guru's " out there..... please identify the slave cylinder and possible part # sources?? I know someone has the answer....
See photo in my galery.... couldn't get it directly into thread...
Old 03-28-2002, 09:40 PM
Send a message via AIM to Rolling Thunder
Default Hope this helps...
Looking through a copy of a 1987 "Assembly Manual for the Contemporary Cobra Replica" it states "...clutch slave cylinder, (Girling #64967010) and slave cylider mounting bracket (both included in the DHB Package) ..."
Since I didn't assemble mine and I am a bit clutch ignorant, I will also include the following from the same manual copy:
"Clutch Release Fork
Listed below are the proper clutch arms for use with 4/5 speed manual transmissions.
Ford V8 (All) Ford Part # DOTZ7515-A Pivot C8AZ7522B
Chevrolet V8 (All) Chevy Part # 3892632"
I really hope that gives you what you need.
Keith
Old 03-29-2002, 06:22 AM
John McMahon's Avatar
Cobra Make, Engine: SOLD: 2013 Boss 302 Mustang #2775 (both options). SOLD: 95 Mustang Cobra R #4 of 250 "Rosie's Diner" car. SOLD: CCX2-2505, #5 of 7 289 FIAs ever produced at Contemporary! my first Cobra: Unique 427SC w/ 428CJ moder!
use the search function...use the search function...use the search function...
Just discussed right here last week:
Good source for Girling???
Screw the rest and just order a CNC slave cylinder, part #350 (pushing slave). Order the plunger too.
CNC Inc
San Diego, CA
619-275-1663
P.S. - in your picture.....you may also want to check the angle on the plunger, it sure doesn't look straight. That is also a major cause of slave failures. Realign it, move the mount!!!
REMEMBER....In Case of Spin....Both Feet in!!!!!
Old 04-05-2002, 09:36 AM
SCOBRAC's Avatar
Cobra Make, Engine: -Sold- Contemporary 427S/C # CCX-3152 1966 427 Med Rise Side Oiler, 8v 3.54:1 Salisbury IRS, Koni's.. (Now I'm riding Harleys)
I think we talked about this in e-mail. You have the Girling unit listed above. It is a .750 bore and you should be able to rebuild it, but a new one is like $65.. If you need one search "Jag parts" online I think the one you have is about a 72-74 e type unit although I am sure there are other cars out there with the same one.
In your photo the clutch fork is not installed yet and what john says is true, if the rod is not almost straight your slave will wear prematurely.
michael
A man that is young in years, may be old in hours, if he have lost no time. But that happeneth rarely. Generally, youth is like the first cogitations, not so wise as the second. For there is a youth in thoughts, as well as in ages... Sir Francis Bacon (1561-1626)
HTML code is On
