SUPPORT OUR SPONSOR
January 2025
26 27 28 29 30 31
Old 07-07-2002, 07:02 AM
Cobra Make, Engine: B&B w/FRPP 347ci 450HP Crate
Send a message via AIM to OhBuoy
Default PCV Routing
I have the following setup...
302 engine rebuilt
Cobra Valve Covers (Passengers side has a round hole with ears that accepts a standard oil cap, Drivers side has a tall tupe with a breather cap on it. I just purchased a breather cap with a nipple on it for a PCV setup.
Edelbrock Performer RPM intake.
Holley 600 Carb.
Cobra oval air cleaner.
What is the best way for me to route my PCV setup?
Thanks for the help,
Tom
Old 07-07-2002, 08:37 AM
Bob In Ct's Avatar
Cobra Make, Engine: SPF - 351W, 944 non-turbo
Hey Tom:
Do not route the PCV hose to the manifold! It should go to the PCV port on the carb (if it has one). If you connect it incorrectly it will lean out the mixture. I'm going through the same question with my 80508 Holley.
Bob
Old 07-07-2002, 09:58 AM
You should always do a search first, then ask.......
I have found that we have all been there or done that and believe it or not most every question has been asked. Anyhow that was my same question 2 weeks ago......lol
Dumb question on PCV routing etc
Tim
Old 07-07-2002, 10:05 AM
Cobra Make, Engine: Classic Roadsters, Tweaked 351W, T-5Z, CRII Tech Support Team.
Once again...
There should be a 3/8" hose fitting on the front or rear of the carb base plate. The PVC is hooked up there,
If there's another vacuum port on one of the intake manifold runners, it's for the power brakes.
HTML code is On
