SUPPORT OUR SPONSOR
January 2025
26 27 28 29 30 31
Old 09-01-2002, 09:57 AM
Cobra Make, Engine: B&B w/FRPP 347ci 450HP Crate
Send a message via AIM to OhBuoy
Default T-5 Neutral Safety Switch
Is there a neutral safety switch on the T-5? My 5-5 has two electrical connections, and I tried both to see if they are Neutral. One is obviously reverse, and I seem to remember seeing that the other is a sensor of some sort.
Old 09-01-2002, 10:24 AM
Cobra Make, Engine: Classic Roadsters, Tweaked 351W, T-5Z, CRII Tech Support Team.
The T-5 has two electrical connections. One is for the backup lights, and the other is the neutral safety switch.
Needless to say, brand new trans, the neutral safety switch had to be bypassed because it stopped working. Haven't replaced it yet.
Old 09-01-2002, 10:36 AM
Which one is the neutral safety?
Old 09-01-2002, 10:57 AM
Neutral safety, at least on my T5Z is up near the front top of the trans, on the drivers side, sticking out sideways just behind the bellhousing.
Old 09-01-2002, 11:21 AM
Slow Dawg's Avatar
Cobra Make, Engine: 2 Seat Roadster-by B&B, 460+ w/auto.
Post
Tom, on my first Cobra that I built in '96-97, I didn't mess with the trans lockout. I installed a lockout on the clutch pedal. I made sure the clutch was totally disingaged before the starter worked.
ps. I'll tell you later what I'm going to do for my "back-up lights".
Nonconformist. Can't handle a real job.
Old 09-02-2002, 01:20 AM
Ron,
Any tips for mounting a clutch lockout on the stock B&B pedal box?
Back up lights? Who has time for going in reverse? Must be for when you let the rear end get away from you or something!
BTW, any tips for wiring up the Lucas bulbs like the ones on the B&B demo car with the Haywire harness?
Tom
Old 09-02-2002, 06:44 AM
Shade Tree Mechanic
Cobra Make, Engine: - Unique - 302 - 4 spd. -
Neutral safety switches have their place....... but not having one has saved me from having to push my car on more than one occasion. Put the tranny in gear and let the starter move the car!
- Jim -
- Jim Harding -
- Capital Area Cobra Club -
- Just another day in Cobra Paradise -
Old 09-02-2002, 08:23 PM
Agreed. Starter does move car nicely. On a level surface, car can be pushed with one hand. Paing shop guys couldn't get over how easily car rolled. I'd be inclined to put a by pass switch somewhere when I wanted to override the neutral safety switch, and leave the safety function in place. Save me from whacking the nose on a curb.
Old 09-03-2002, 06:35 AM
Cobra Make, Engine: B+B 351w #112
Never found a use for hooking up the switch. I always push in the clutch when I start the car. Even when I know its in neutral. Just a good habit. Jim
Old 09-03-2002, 08:35 AM
Do you use a clutch switch then? How did you mount your clutch switch if you use one.
Tom
Old 09-03-2002, 02:18 PM
PNJSNAK's Avatar
Club Cobra Member
Cobra Make, Engine: A&C 427S/C, 351W, T5
Tom: The switch was there and I wired it in. I still push the clutch in at times, old habits are hard to break. It is easier to start on an incline, because you can keep your foot on the brake and still play with the gas pedal. My 2 cents.
Jim
OhioCobraClub.com
HTML code is On
