SUPPORT OUR SPONSOR
January 2025
26 27 28 29 30 31
Old 09-13-2002, 10:58 PM
brizz's Avatar
Send a message via AIM to brizz Send a message via Yahoo to brizz
Default jag rear ends.....
hey guys what kind of fluid is best for the jag /spicer?
thanks Brizz
brizz
Old 09-13-2002, 11:50 PM
Turk's Avatar
Cobra Make, Engine: What Cobra?
Send a message via Yahoo to Turk
Moroso Climbing Gear Oil.
TURK
Per ERA Manual
OBAMA IN in 2012
Old 09-13-2002, 11:55 PM
Cobra Make, Engine: Contemporary CCX33868 Sold. Just "playin' the boards now."
Jag is Salisbury made by Dana. They have steel clutches if they are limited slip. If not limited slip, any good 90 Weight hypoid gear oil will work. If they are limited slip, the oil needs the limited slip additive. Either buy the oil with the additive already in it or buy a small bottle and add as directed.
BTW Don't try to mix and match Dana and Salisbury parts. Put them side by side and you'll quickly see why. That said, you can put in all Dana parts and they will fit. Hunting up the right bearings is a pain, but it can be done. It's a lot cheaper than trying to chase down Salisbury parts and pay through the nose for them. Also, Dana has a lot more gear ratios to offer. Want 3.77's like original S/C's? Probably can't find Salisbury's, but you can get Dana 3.73's from any parts house in America.
"If some is good, more is better.
And too much is just enough."
--Carroll Shelby
Old 09-14-2002, 12:16 AM
brizz's Avatar
How do I identify what jag rear end I have? also .... Turk, I went to the moroso web site and looked for that climbing gear oil and found nothing. Btw what a stupid name for gear oil! lol it just struck me funny..
brizz
Old 09-14-2002, 06:03 AM
Availability of the Moroso Lube has been spotty.
From our latest assembly manual :
Differential: Fill with Moroso climbing gear lube, SAE 90, part number 34800, mixed with 4 to 8 oz. of Amalie limited slip additive (part # 505-6775). If the above are not available, you may use 80W-90 GL5 lubricant with an equivalent limited slip additive. If the limited slip seems to be sticking (ratcheting around sharp corners), drain and refill, replacing the Amalie additive with 2 tubes of GM additive 1052358.
Bob Putnam
-E.R.A.-
Please address parts inquiries to eraparts@sbcglobal.net
Old 09-14-2002, 01:29 PM
brizz's Avatar
Wink jag rear end
Thank you Bob!! you just gotta love the the cobra club. It makes owning a cobra even more fun....
brizz
Old 09-17-2002, 07:52 AM
mickmate's Avatar
There is an aluminium tag on a bolt for the back cover. It will either give a ratio directly like 2.88 or the numbers of the teeth on ring and pinion that divide to the ratio. A Snake, I thought the originals had a 3.54 ratio? I figure the 3.73 is close enough.
Cheers Nick
mickmate
http://www.actoncustom.com/
HTML code is On
