SUPPORT OUR SPONSOR
January 2025
26 27 28 29 30 31
  #21 (permalink)
Old 01-21-2003, 11:27 PM
Cobra Make, Engine: Contemporary CCX33868 Sold. Just "playin' the boards now."
Sal,
Your pictured manifold is a 68 version. C8AE and was intended for the 428 SCJ engine.
It's not the height of the carb surface that separates med riser from low riser, it is the position and shape of the intake runners themselves.
Al
"If some is good, more is better.
And too much is just enough."
--Carroll Shelby
  #22 (permalink)
Old 01-22-2003, 12:30 AM
Sal Gerace's Avatar
Club Cobra Member
Cobra Make, Engine: CSX4300, C5AE-H, Toploader
Hi Al,
It's a 63. Here's a close up of the number, Sal.
  #23 (permalink)
Old 01-22-2003, 08:50 AM
M & M's Avatar
Cobra Make, Engine: JCF 427 - FE 427 SO
Send a message via ICQ to M & M
Post Port Size
How about a picture of the intake ports. As Al pointed out there are a big difference in the size of these when comparing the low rise and the medium.
If you look in my galley there is a picture of the intake ports on a pair of low riser heads. You can see the massive height of the low riser intakes. A medium riser is more square in shape.
If we could see a picture of the ports on the intake it should solve the issue?
Regards,
Mike
"There's nothing like the sound of a BIG BLOCK!"
  #24 (permalink)
Old 01-22-2003, 08:04 PM
KobraKarl's Avatar
Well Sal we have low rise manifolds.
To confirm this i took my little shop mirror and a mini mag lite and took a look down through the throttle openings (w/o carbs on),at first i thought it wasnt going to work ,but a little trial and error and i could see to the valve stems! ...................also about 3/16 of shiny milled metal along the bottem of each runner as it mated with the head............ damn!! ......................
any one like to sell a med riser? any one want to buy a low one ?
  #25 (permalink)
Old 01-23-2003, 06:00 PM
SCOBRAC's Avatar
Cobra Make, Engine: -Sold- Contemporary 427S/C # CCX-3152 1966 427 Med Rise Side Oiler, 8v 3.54:1 Salisbury IRS, Koni's.. (Now I'm riding Harleys)
Thumbs up C3AE-9425 (A) or (k)
Yes frequently particularly early in '63 manifolds were unmarked. the K suffix was a later unit likely installed on a 428, but look at the way the number is stamped and not cast, this co mingling of parts was common. Karl's is an "A"..
michael
A man that is young in years, may be old in hours, if he have lost no time. But that happeneth rarely. Generally, youth is like the first cogitations, not so wise as the second. For there is a youth in thoughts, as well as in ages... Sir Francis Bacon (1561-1626)
  #26 (permalink)
Old 09-26-2003, 06:54 PM
Cobra Make, Engine: LA Exotics, Ford 428
I have a C3AE-9425-H intake manifold...does the "H" indicate a high-riser?
LA Exotics '66 SC Cobra
HTML code is On
