SUPPORT OUR SPONSOR
January 2025
26 27 28 29 30 31
Old 02-05-2003, 08:33 PM
Default Everett-Morrison body fit on Midstates Frame
Anybody know if the Midstates frame will fit under an Everett Morrison body without any complications? It is a square tube frame.
EndiKarz
Old 02-07-2003, 12:03 PM
Cobra Make, Engine: E-M , 5.0 efi
Heres what I remember about putting my EM body on the frame.
First off the body is very strong. If you change the mounting points a bit from what EM did I think you will be OK.
The EM mounts at 8 points.(4 on each side) From front to rear they are: The inner wheel well in front of the front axil.
the floor of the passanger compartment sits on the round tubes of the EM frame. one mount is by your feet and one by your seat.
The rear mounts are all the way back by the bumper mounts.
I would think the big question would be the frame height of the two companies where the pasanger compartment is. Frame too low and you could block it, but if the frame is too high it may be hard to make the body sit low enough.
Let me know if you want me to take some measurments of my EM.
Good Luck
Old 02-07-2003, 12:15 PM
larryar's Avatar
Cobra Make, Engine: CACC Member. Power Performance, 2X4's, 428
Default E-M frame
You can get an Everett-Morrison duplicate frame from Autovision
717-382-4312
Big Blocks Rock!
Old 02-07-2003, 12:27 PM
mikiec's Avatar
I can tell you this...
It has been done in the reverse.
BT Snake has a Midstates body on an EM frame.
Mike
HTML code is On
