03-08-2003, 08:01 AM
NC
Cobra Make, Engine: ERA 427SC w/427so, ERA GT #2002
Michael, Doesn't matter how many carbs your engine has when choosing fuel-pump requirements. What matters is max power output. For example, a 350hp engine will require 29 gallons per hour at constant full power or 58 gph for 700hp.
Using Holley's red pump as an example, it will flow 97 gph @ 7 psi. the blue pump ups this to 110 gph @ 14 psi. If you have a real "serious" engine and drive it real "serious", one of their two black pumps may be for you. They flow 160 gph and 250 gph, respectively, at 15 psi. Both require 3/8 inch return lines because that's where most of the fuel will be flowing . . . back to the tank.
If it was me, I would install two blue pumps with two pickups, Y out at the engine, feed into one pressure regulator each, then into each carburetor.
For detailed information on pumps and plumbing, check out Holley's web site: http://www.holley.com/HiOctn/TechSer.../FMFPTech.html
Good luck.
Tom
"If you can make black marks on a straight from the time you turn out of a corner until the braking point of the next turn, then you have enough HORSEPOWER." Mark Donohue
