SUPPORT OUR SPONSOR
March 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
30 31
  #21 (permalink)
Old 01-28-2004, 08:48 AM
DonC's Avatar
Cobra Make, Engine: ERA #684, 428 FE, TKO600
With the electric solenoid it can be shut off as soon as the engine has been pre-lubed. The solenoid in the closed position has a one-way capability that allows the accusump to recharge with the solenoid in the off position.
DonC
  #22 (permalink)
Old 01-28-2004, 05:53 PM
I've had both. Current 520cid aluminum engine has the Preluber. Computer controled to pump oil as long as you want during "dry" start up. And the same feature during shut down so the oil left in the hot bearings does not cook. The shut down feature is mainly for the turbo guys, but makes sense to me. Can also program to come on at a low oil preasure condition. This only works if you have a second pick up point in the oil pan, which I have.
Richard
Memphis
  #23 (permalink)
Old 01-28-2004, 09:24 PM
Cobra Make, Engine: '02 Civic EX Coupe & '95 supercharged SHO
Send a message via AIM to yamahaSHO
DonC
Thats EXACTLY what I was looking for!!!
You guys have pretty much answered all of my questions. THANK YOU VERY MUCH! I hope you guys don't mind me on your forum even though I do not own a Cobra or anything close to it.
Thanks again!
  #24 (permalink)
Old 01-30-2004, 01:29 AM
I am going with an electric valve, which of the two would you recommend? I am thinking E.P.C.
thanks,
  #25 (permalink)
Old 02-11-2004, 09:25 PM
I decided to order my system... Could not go with the EPC valve as my hot idle oil pressure runs lower(12.8psi) than their lowest valve(20-25psi)... I went with the regular electic valve.
Whole kit cost under $375.. not too bad, IMHO.
Thanks for all you help guys!
  #26 (permalink)
Old 02-12-2004, 11:07 AM
PSB's Avatar
PSB PSB is offline
Cobra Make, Engine: RCR SLC, Graziano 6-spd, LS3
Jason,
You might have seen this already, but if not: SHO Powered Cobra
Pete
  #27 (permalink)
Old 02-12-2004, 07:42 PM
Originally posted by PSB
Jason,
Pete
Thanks! But yeah, I've seen it... I have seen SHO powered Healy's(sp), trucks, GT-40 etc... I have even driven a SHO powered sand rail.
GT-40 on Fiero body...
Sand rail w/ 3.2 SHO motor... Very fun to drive! Will be turbo charged this year.
Todd Cooks Hill aluminum Hill Climb car... SHO motor with custom intake and many other mods... Took 2nd(or 3rd?) at Pikes Peak this past summer.
HTML code is On
