SUPPORT OUR SPONSOR
December 2024
Old 01-30-2004, 01:15 PM
Curt C.'s Avatar
Cobra Make, Engine: Classic Roadster; 351W
Default Electrical Relay Question
I want to use a relay on my fuel pump. The fuel pump requires a 7.5 amp fuse. Do I need a 7.5 amp relay or can I use the standard automotive relays which are rated at 30 amp. I am slowly getting a handle on this electrical stuff. Thanks for the replies.
Old 01-30-2004, 01:25 PM
Cobra Make, Engine: FFR4067, 393W
Use a relay at least double the fuse amps. Bigger is better.
30A would be excellent.
You should still use the recommended fuse, to protect the pump motor.
HTH, Ed
We used to own the government, now the government owns us. Where'd we go wrong?
Old 01-30-2004, 02:57 PM
Curt C.'s Avatar
Thanks Ed.
Old 01-30-2004, 04:03 PM
petek's Avatar
Cobra Make, Engine: CRL, 351W, Tremec TKO
(going to sound like a real "duh" if you already know this, but I'll offer it up anyway...)
Don't forget, the fuse goes on the contact side of the relay, not the coil side of the relay.
Pete K.
Who is John Galt?
Old 01-30-2004, 04:18 PM
vettestr's Avatar
Cobra Make, Engine: Cobray-C3, The 60's body lines on todays chassis technology
Curt,
Another consideration should be wire size for the LOAD. The load or side of relay that supplies the current to fuel pump should be a minimum of 14 AWA gauge wire. The length of wire needed should not be long enough to demand a larger wire gauge.
Since we are talking about an electric fuel pump = concern with impact or turnover is a thought. Painless sells a relay setup for this concern.
Jeff Classic
Manufacturer of the Cobray-C3
www.cobrasnvettes.com
Old 01-30-2004, 05:21 PM
Bruce Edwards's Avatar
Cobra Make, Engine: Hunter with a 4.6 supercharged
You may wish to install a fuel pump shut off tied in to your engine oil pressure as a safety. When the motor is not running no pump. When the engine is cranked and oil pressure goes up the pump comes on. Can cut down on those nasty fuel feed fires if you have a problem.
Bruce Edwards
Gemini Motorcars Inc.
Bruce Edwards
http://home.bellsouth.net/p/PWP-GeminiMotorcars
Old 01-31-2004, 02:52 PM
Curt C.'s Avatar
Thanks guys. I just recently learned the power of the relay. Petek, no, I never really thought about that. So fuse goes between the relay and the pump in this instance? I already have the ground wired to a oil pressure switch so I think I am safe there. I will make sure to use the appropriate sized wire.
Curt
HTML code is On
