SUPPORT OUR SPONSOR
January 2025
26 27 28 29 30 31
Old 03-30-2004, 05:25 PM
Specialk's Avatar
Cobra Make, Engine: 427 SC
Send a message via AIM to Specialk Send a message via Skype™ to Specialk
Default IRS Pinion Angle?
Ok gearheads, I got a question for you. I am finding all sorts of conflicting information concerning the pinion angle VS the engine angle. Does anybody know what the optimum pinion angle is for a IRS car? What about the engine angle? Assume a Ford engine(If that matters?) and a Cobra for the application.
Thanks
kris kincaid
Old 03-30-2004, 05:47 PM
Tom Wells's Avatar
Hi kris,
Did you look here yet?
Pinion angle discussion on Club Cobra
If you do a search here, you'll find even more
Regards,
Tom
Old 03-30-2004, 06:31 PM
Cobra Make, Engine: Kirkham #259
Kris
Here's something from Denny's Driveshaft service...
I've got some drawings .... just have to find them...
http://www.dennysdriveshaft.com/
How much driveline angle is right for my application?
Thats a loaded question. The best answer is....the least amount of driveline or u-joint angle is the best amount of angle. Try to achieve the least amount of u-joint angle but don't make it less than 1 degree. A little known fact about u-joints is that they require about 1 degree of operating angle to get the needle bearings rotating. If they do not rotate they will fail. Too much angle will also cause them to fail. The type of rear suspension also plays a big part in setting the angles as well as the engine/transmission angle. Leaf spring cars have a need for more downward pinion angle due to spring wrap-up while coil spring cars control the situation better. Hard acceleration as in the case of a drag race car requires a different setting than a street driven car. Traction bars, ladder bars, 4 links, independent rears all have special needs and requirements.
Hope this helps....
Morris
Morris
Old 03-30-2004, 08:05 PM
Kris
Here's the document that will help the most...
http://www.drivetrain.com/driveline_angle_problem.html
Morris
Morris
Old 03-30-2004, 08:47 PM
Cobra Make, Engine: 2 dr roadster, V-8, 4 spd.
Morris,
What is in your head would make a great book for folks like me, and Kris, and TURK, and LNP, and SFCJ, and about a zillion other gearheads...something like the magic tricks magicians only share with each other book. Great stuff.
Old 03-30-2004, 09:02 PM
TC...
I'm just lucky to be able to participate in the ability to break and destroy things..... it's called experience.... then I know what not to do.....
Like trying to knock 2 seconds of your lap time at RR and then the ride...... and then the smile on your face when you come in.... damn what a great time....
Nothing like it.... Huh.... >????
Morris
And yes this board is a good place to pass it down to others...
Morris
Old 03-30-2004, 09:04 PM
BTW
Those other guy's would probably throw me out of the room after 10 minutes....
Morris
Old 03-30-2004, 09:13 PM
Specialk's Avatar
Thanks Morris. I like "the least amount of driveline or u-joint angle is the best amount of angle". I'll keep that in mind!
kris kincaid
Old 04-03-2004, 04:32 PM
Cobra Make, Engine: have engine, but no car yet
Post Pinion Angle
Pinion angle is the same as the engine, whether they are parallel to each other or not.
keeponkeepinon
HTML code is On
