April 2025
6 7 8 9 10 11 12
13 14 15 16 17 18 19
20 21 22 23 24 25 26
27 28 29 30
Old 06-14-2004, 09:06 AM
Cobra Make, Engine: B&B 408W, TKO 600, 9" 4-link Truetrac, 13" X 1 3/8" curved vane frt disks
Default 10.5 or 11 inch clutch 408W?
I bought a Mcleod 10.5 inch 800 series clutch plate and a 10.5 inch diaphram pressure plate. I also have the 164 tooth steel flywheel which will accept either 10.5 inch or 11 inch clutch. My setup is 408W, TKO, ford 9" rear.
Should I exchange my 10.5 inch clutch plates for 11 inch plates?
Old 06-14-2004, 09:09 AM
bigger is better! I went from an 11.5 to a 12 inch McCleod myself. You need all the clutch you can get it.
Old 06-14-2004, 09:24 AM
I don't know...these cars are awfully light. I think if you're running slicks...sure...but not with street tires...and not with a 2300 lb car. I'm running a 425ci Windsor, 9" rear and a Toploader....I have a 10.5 Hays Street/Strip disc and a 10.5" Hays Street/Strip B&B pressure plate....rated for about 2800 lbs clamping force.
Old 06-14-2004, 12:29 PM
Excaliber
Can you get a 12 inch clutch on a 164 tooth flywheel? Were you using a diaphram or long style pressure plate?
Blykins
No slicks and no drag racing, only street and road course.
Old 06-14-2004, 12:38 PM
Dave, Excal is running a big block.....the flywheels are a little bigger and usually drilled for bigger pressure plates/clutches....
I'd stick with the 10.5" piece....should be fine....
Old 06-14-2004, 05:09 PM
Cobra Make, Engine: BDR 89 KEITH CRAFT ALL ALUMINUM 427 WINDSOR
DaveR
I bought a Mcleod dual disc setup, 10.5 inches. On a chassis dyno , I promise there is no slippage. When we testing, some of the best single disc setups would show slippage after about 400-415 rear wheel horsepower. I think I paid about $1400 for eveything, aluminum flywheel, cutch-pressure plate set-up, and their steel bellhousing. On the street, it has very easy pedal effort, when she grabs it is locked for sure.
DON
Old 06-15-2004, 04:52 PM
392cobra's Avatar
6th Generation Texan
Don,
I have a Keith Craft 408 on order.It will be in the 450-460 rwhp
and have decided to go with the McLeod Street Twin Disc as well.
Are you using a slave cylinder or hyd t/o bearing ??
Old 06-15-2004, 05:04 PM
Gasman's Avatar
Cobra Make, Engine: Unique, S.A. 427 center oiler
bigger is better. If 12" is possible, you should go there.
Steve
Old 06-15-2004, 05:42 PM
FRED
I am using a hydraulic t/o bearing assembly. Man you won't believe how easy the thing works. Saves a bunch of space around where the slave cylinder suppose to be. Looks a lot nicer too. It is also the Mcleod unit. Congrats on the Kieth Craft motor, I love mine, you will love yours too.
DON
