SUPPORT OUR SPONSOR
January 2025
26 27 28 29 30 31
Old 02-18-2005, 05:45 PM
Cobra Make, Engine: 1965 West Coast Cobra 351 Windsor 400 HP
Default Rag Joint Replacement?
On the Mustang II front end of my Cobra, the steering rag joint is damaged/coming apart. The 'rag' is rubber to dampen the steering, right? Can I do without it? Can't seem to find a replacement part in Jegs or Summit. Do I have to replace the whole steering joint? Maybe a Ford dealer sells just the 'rag".
Thanks
Old 02-18-2005, 09:32 PM
Bob In Ct's Avatar
Cobra Make, Engine: SPF - 351W, 944 non-turbo
I would not eliminate it if I were you. I wish I had one, instead I have steering wheel shake.
Bob
Old 02-18-2005, 09:57 PM
Cobra Make, Engine: Classic Roadsters, Tweaked 351W, T-5Z, CRII Tech Support Team.
Both Flaming River, and Borgeson make a damped connector that replaces the rag joint, and is a lot stronger and tighter than a rag joint. Steering wheel doesn't vibrate, but steering response is substantially improved.
Old 02-19-2005, 12:06 AM
bill bradshaw's Avatar
Cobra Make, Engine: everett morrison 351w
I replaced the uper u-joint with a Borgeson dampner joint ($100). The vibration at 55mph has been removed. Check out Borgeson.
HTML code is On
