SUPPORT OUR SPONSOR
December 2025
  #61 (permalink)
Old 04-18-2005, 07:52 AM
Never had a choke....it's a Mighty Demon.
I had a lot of stuff going on this past weekend. Found out my battery probably has a shorted cell. Alternator works though.
Past couple of weeks when I went home to work on the car, I noticed that on a cold start, it was harder to keep it running than usual and it didn't start as quick. Usually I pump it half throttle 3 times and it fires right up and doesn't die. This time it would fire and run then die....Then when I could keep it running I would notice a slight miss on the driver's side and it would pop a few times...
After it warmed up, it was a little better....but still had a slight miss when holding the throttle around 2000 revs...Didn't seem to have as quick of a throttle response as usual. When I shut it off and let it set for a few seconds, I'd have to give it a couple of pumps to get it to start again....
I changed plugs this past weekend. Went with Champion RC12YC's.
Dad came up to the garage and he couldn't hear what I was hearing, but I insisted that it wasn't acting the same. After a buddy came over, I fired it up again, and for some reason Dad heard it that time. While I was still in the car, he grabbed a screwdriver and set the mixture on all four corners. The miss went away at 2000 revs....and it started as quick as it used to. I shut it off and let it sit for a little bit....then while standing outside of the car, I reached in and hit the key to start it....started instantly without having to give it any gas.
So it seems like everything is back the way it used to be. I watched Dad when he adjusted the mixture screws, he
ran the driver's side screws out. So that means he richened that side up, right?
Everything seems fine now....I'm just trying to work things through logically in my mind as to what condition causes what symptoms.
I'll try to call you after I get home from work Bruce....it will probably be around 4PM EST. Thanks for the offer.
Lykins Motorsports, LLC
www.lykinsmotorsports.com
www.customfordcams.com
brent@lykinsmotorsports.com
  #62 (permalink)
Old 04-18-2005, 08:14 AM
Bruce Edwards's Avatar
Cobra Make, Engine: Hunter with a 4.6 supercharged
Sounds like your Dad hit the right setting for your set up. With out a choke it should be a pain to start and keep running when it is cold. All settings should be made with the engine at running temp. With out a choke the fuel mix will be lean when cold. If you try to set it up everything will be off when it warms up.
Playing with the mix screws on ht efront should not have made much of a change how ever the rear ones would as the back side is not open so it will add fuel like it was at idle.
Does that help?
Bruce Edwards
Gemini Motorcars Inc.
http://home.bellsouth.net/p/PWP-GeminiMotorcars
  #63 (permalink)
Old 04-18-2005, 09:44 AM
Yep, makes sense to me.
Just wondering about it being lean....never have heard of a lean condition causing a miss....but it should did clear up when he richened it up. Started so easy and quick too.
Thanks Bruce.
  #64 (permalink)
Old 04-18-2005, 09:57 AM
If it is to lean it will cause a miss. Not enough fuel in the intake will give a cylinder or two a very lean shot of fuel and you will see it as less power on one cylinder i.e. a miss.
Bruce Edwards
  #65 (permalink)
Old 04-18-2005, 10:08 AM
Learning more and more everyday. I try to apply logic to this stuff, but sometimes it just doesn't work for me.
Thanks again...you're a gentleman and a scholar.
HTML code is On
