SUPPORT OUR SPONSOR
September 2024
Old 04-29-2005, 12:05 PM
EarlsflyinCobra's Avatar
Ouch Ouch Hot Sand
Cobra Make, Engine: Street Beasts w/302 Twin Turbocharged....Under Construction!!
Send a message via AIM to EarlsflyinCobra
Default Will these work?????
9.5" x 17" wheels by P. S Engineering, 5" backspace
Will these work, adding adapters of course, on the Ford Mustang rear end used in my Cobra build, or will the spacing be off???
Thanks, Earl
Safe Flyin, errrrr Drivin, Earl
Old 04-29-2005, 12:19 PM
What's the rearend length?
www.lykinsmotorsports.com
Old 04-29-2005, 12:25 PM
Ouch Ouch Hot Sand
I'll have to check but I think it is 51 1/2" for some reason....Earl
Old 05-01-2005, 08:29 PM
Ouch Ouch Hot Sand
My hub width is 59 1/2" and my build book says wheels with "standard" offset, what ever that is.
Now can someone tell me if these will work or not????
PLEASE...................
Old 05-02-2005, 06:16 PM
351-EM's Avatar
Cobra Make, Engine: Everrett-Morrison Cobra, 427W T-5 Z tranny
Earl,
I am assuming that your using a solid axle 9" or 8.8" rear right? I just went through a fiasco with my Everett-Morrison Cobra as I tried to put a 52 1/2" hub to hub 9" rear in my chassis and use the standard Trigo wheels (3 1/2" b.s.). No way Jose! I ended up having to sell the rear Trigo's for dirt and order a set of custom 6" backspace rears from Phil @ PSE Wheels. If you have have a 59+" rear hub to hub, you may be in for a very rough time. You can also check the width of the body at the rear wheel arches, but I am willing to bet you can't make them fit without either narrowing the rear or locating an earlier rear that is short from the factory (1955-1959 9" are 52 1/2"). Please let me know if you have any additional questions, I hope to prevent others from feeling the pain I have been through the last 6 months.
Later,
Chris
HTML code is On
