02-27-2006, 09:55 AM
Canadian Gashole
QC
Cobra Make, Engine: Johnex 427 S/C, 351W, 472 HP, 444 lbs. torque
While the Cobra is tucked away in the garage for at least 2 more months (really cold and windy here today, wind chill is something like -35) I believe that I did find the problem as I indicated above. I had a 10 wire connector that wasn't properly hooked together. I took it apart, cleaned all the connections while I was at it, put it back together, and taped the two plastic connection blocks together. I didn't have any difficulties after that.
Iniitally I had my MSD box under the hood but I decided to move it into the trunk when one of my buddies that races quite a bit mentioned that MSD boxes get hot on their own and do not like to be over heated. I store my car in the winter months so I am always looking for projects to keep me busy. I moved the box into the trunk and make a wiring extension using the proper colour wires. I soldered all of the connections and covered each in shrink wrap to make sure that I did not have a problem in the wiring. An added benefit is that it keeps the engine compartment more tidy.
By the way, the wiring connector that gave me the problem had nothing to do with placing the box in the trunk. It was a connector used to separate the wiring harness under the dash from the rest of the wiring harness especially that part under the hood.
Wayne
Don't get caught dead, sitting on your seat belt.
