SUPPORT OUR SPONSOR
January 2025
26 27 28 29 30 31
Old 07-17-2006, 11:08 PM
Default Coil in ALL brake lines, why?
Hey guys! I'm about three weeks out from finishing the car, I can't wait!
I'm in the process of installing the brake system in my car. I noticed at a car show last week that every car has a "coil" of brake line just near the master cylinder. What is the purpose of this coil, or "loop" of line? Bleeding, air bubbles, to ward off aliens? If I don't need to put it in there, I'd prefer not to, making the lines look cleaner. Thanks guys!
Lance
Old 07-18-2006, 12:19 AM
Cobra Make, Engine: ERA 427 w/496 Side Oiler, roller, dual quads
It's there for vibration and to allow the line to expand and contract if necessary, so the line doesn't eventually break.
Do you know why they call it "PMS"? Because "Mad Cow Disease" was taken. --Unknown, presumed deceased
Old 07-18-2006, 06:09 AM
trularin's Avatar
Member of the north
Cobra Make, Engine: A Cobra
Two reasons; vibration and temperature.
Unless you are talking about the coils that go over the lines, those are for abrasion.
Old 07-18-2006, 08:55 AM
SCOBRAC's Avatar
Cobra Make, Engine: -Sold- Contemporary 427S/C # CCX-3152 1966 427 Med Rise Side Oiler, 8v 3.54:1 Salisbury IRS, Koni's.. (Now I'm riding Harleys)
Ease of installation and to a lesser degree expansion. You don't want them to bind but why would they if you have a little slack in the line?
michael
A man that is young in years, may be old in hours, if he have lost no time. But that happeneth rarely. Generally, youth is like the first cogitations, not so wise as the second. For there is a youth in thoughts, as well as in ages... Sir Francis Bacon (1561-1626)
Old 07-18-2006, 01:09 PM
rdorman's Avatar
Renegade Nuns on Wheels
Standard practice for many years was to add a 'service' loop at the end of every hard line. The reason was if the line broke or other wise became not servicable, you could just straigten out the cut and flair a new fitting on with out having to replace the whole line. This is a fairly 'old school' way of doing things. I don't bother any more. Done wrong it can make bleeding the brakes more of a pain as well.
Dave, 'temperature'... running them brake lines through a cool can are you
OhioCobraClub.com
LondonCobraShow.com
Old 07-18-2006, 01:18 PM
Flyin_Freddie's Avatar
Cobra Make, Engine: Superformance #770, Stroked 351W (393 cubes) w/ Tremec TKO-600, 3.27 Torsen locker, 'Hi-Tech' Blue w/ White Stripes, Wilwoods, Bilstein coil overs...and a big ear-to-ear grin!
rdorman wrote...
"...running them brake lines through a cool can are you..."
Anything for an edge, Rick...anything for an edge....
Flyin_Freddie
"An opinion on everything...an expert at nothin'!"
WARNING: The opinions expressed herein do not necessarily represent those of the management, editors, or owners. We welcome differing opinions, and recognize our responsibility to offer differing views. May cause drowsiness, restlessness, or irritability. Do not operate heavy machinery while using this product. Void in Alaska, Hawaii, and Puerto Rico, or where prohibited, licensed, or regulated by law. We reserve the right to limit quantities. Offer good while supplies last. No substitutions allowed. Please observe posted speed limits. Professional driver on closed course. Do not try this at home. Please wear your seatbelt at all times. Close cover before striking. Use at own risk. Please dispose of properly. Drink responsibly. Prolonged exposure to vapors has been shown to cause cancer in laboratory animals. Do not use this product of you are pregnant, or plan on becoming pregnant. Intentional misuse by deliberately concentrating and inhaling fumes can be dangerous. Always wear safety glasses. In case of eye contact, flush with water and seek immediate medical attention. For occasional use only as directed. Avoid prolonged skin contact. Discontinue use if rash develops. If symptoms persist for more than three days, seek professional medical attention. Hearing protection required beyond this point. Danger: Hot surfaces. Use as directed. Proceed at own risk. Caution: Filling may be hot. Please don't litter. Actual results may vary. It is a violation of Federal Law to use this product in a manner other than as intended. Do not use this product if you have an enlarged prostate, or have difficulty urinating.
Old 07-18-2006, 01:21 PM
rdorman's Avatar
The only thing I run through a cool can Freddie is various alcohols.... and they aren't the kind that the motor runs on either!
OhioCobraClub.com
LondonCobraShow.com
Old 07-18-2006, 03:15 PM
trularin's Avatar
Member of the north
That's what I figured you were at Rick.
The car companies would never add line if they did not have to. There were short runs to the metering valve just under the master cylinder. but the temperatures would cause a problem in the summer as the water would boil close to the exhaust. One fix was to increase the dispated area and drop the temp.
On top of that, they had a number of cars that were not unibody and the body mounts would come apart from the frame allowing the body to move a little. If there was not a way to allow for the lines to move, they would brake and the brakes would fail.
For a while, lines were run in standard lengths so they could be serviced just about anywhere, but that did not last long as it was expensive.
Old 07-19-2006, 06:45 PM
In most cases, the master cylinder is mounted on the body, and the lines go to a bracket or proportioning valve mounted on the frame. The body is usually attached with rubber bushing allowing flex between the body and frame.
I've actually seen brake lines ripped out of the master cylinder on a drag car where the frame twisted a lot and the lines were run reasonably tight.
Old 10-07-2014, 11:48 AM
Question was asked in 2006 about why people put loops near the connection ends of brake tubing: The answer is still important, so please let me refresh. It has little to with vibration isolation or thermal expansion. It will certainly INCREASE the tendency of the tube to vibrate and could therefore, in principle, lead to failure. Thermally, if heated from end to end with a torch, the tube could lengthen a fraction of an inch (e.g., heat a steel tube 60 inches long to 500F and it will get about 0.21 inches longer -- I wouldn't panic over that.), which is easily absorbed by other flex points in the pipe.
The LOOP has to do with ease of replacement if the fitting goes south. Historically it is called a "service loop" and is there for service reasons, as the name indicates. It can also come in handy if you are using tubing that has flares already made on both ends. If you get to the end of the run and have a few inches of tube left over, coil-it up. Easier than cutting and making a new flare. Of course, some people secretly think it makes the thing look more "racey".
HTML code is On
