SUPPORT OUR SPONSOR
January 2025
26 27 28 29 30 31
Old 07-28-2006, 09:59 AM
Igofastr's Avatar
Cobra Make, Engine: SPF GT40P-2265/393W, KMP318 (PROJECT!!!!!)/CSX478
Question McCleod hydraulic TO
I'm curious how you guys have retained the hydraulic line comming through the scattershield. There sure doesn't seem to be a lot of room in there.
In fact, I only have an extra .5 inch or so between the lines and the PP...is that normal? I mean, I can get my fingers in between the lines and the PP, but not much more. I'm guessing that the close proximity of the lines to the PP means you absolutely have to retain the lines within the scattershield, rather than try to fasten them down once they've exited the housing.
Please let me know what your expeirences have been, what worked, what didn't.
Thanks.
Ron R
"Dishwasher? I thought that was for cleaning parts!?"
Old 07-28-2006, 11:02 AM
xlr8or's Avatar
I have mine fastened outside the bellhousing on the frame in such a way that they are flexed toward the rear of the car. You could make a line clamp with an "L" bracket to attach next to the clutch fork opening.
Old 07-28-2006, 11:03 AM
Cobra Make, Engine: 396W Kirkham KMPS036
I just replaced the old clutch in my ERA with a McLeod setup. The Throwout Bearing is near the Tremmec (only slightly forward of it). The lines fall at the aft edge of the Bellhouseing (also McLeod). I use a homemade clamping device. A piece of .25 thk alum strap is anchored to the lower tranny bolt location. Another piece of strap is mounted vertical with two clamps that hold the hoses. The two pieces of aluminum are connected with a threaded rod and using 4 nuts (two for each aluminum piece) you can adjust the position of the hoses so they are just in front of the bellhousing cutout, well away from the pressure plate. Some heater hose around each tube prevents fraying on the bellhousing edge.
Unfortunately I have no pictures. When assembled it looks like a cross with the hoizontal part coming off the tranny bolt and the vertical part holding the hoses. The two pieces have a fair distance between them.
A picture would sure help.
Anyway whatever you do don't let the hoses get near the pressure plate.
Bob McLinden
ERA FIA 2080 SOLD
Kirkham KMPS036
Old 07-28-2006, 12:12 PM
Cobra Make, Engine: Everett Morrision FE 427 so 2-4s
Hot Rod mag says B&M now owns McLeod .
Mike H
HTML code is On
