-   Shop Talk (http://www.clubcobra.com/forums/shop-talk/)
-   -   Oil Pump Installation - Gasket or No? (http://www.clubcobra.com/forums/shop-talk/72299-oil-pump-installation-gasket-no.html)
CWizard 08-27-2006 05:26 PM
I have been told that when installing an oil pump on my 351W block I should not use a gasket. Does that make any sense? With no gasket, aren't you risking a pressure leak right off the bat (or right out of the pump)? If no gasket is the appropriate technique, could someone please explain why?
Thanks!
Ibr8k4vetts 08-27-2006 05:59 PM
I wouldn't think of running with out a gasket:eek:
jwd 08-27-2006 06:35 PM
Mine came from Ford with a gasket between the oil pump and block and between the pump and the pick up tube. I don't plan on trying to outsmart those engineers.
dynoroom 08-27-2006 10:43 PM
I quit using a gasket years ago. The reason won't please most but if you are an engine builder you would know that many GM engines don't use gaskets. Some of them only have 1 fastner others 2 or 3 (Chevrolet, Pontiac, Olds, ect.) but no gaskets.
Oh.... why did I quit using a gasket on the Fords when they supply one in the kit? Because I failed a gasket (pushed out between the bolts) and had a internal leak. JMO
