SUPPORT OUR SPONSOR
December 2025
Old 10-10-2006, 06:27 PM
JAC's Avatar
JAC JAC is offline
Cobra Make, Engine: Classic Roadsters II
I was told you don't use sway bars with coil overs.
Old 10-10-2006, 06:47 PM
Cobra Make, Engine: original a/c. shell valley 427. daytona coupe
We use nascar style sway bars from speedway engineering in california on all of our race cars. our set ups on the roadsters as well as the daytonas are tubular upper and lower control arms coil overs and various brake set ups. we use speedways arms and straight bars and use various size link bars with hiem joints that allow pre loading if need be. The set ups work great and are very easy to adjust. Im not a salesperson for speedway , but check out there web site.
Old 10-10-2006, 07:44 PM
JAC's Avatar
JAC JAC is offline
Thanks, I just want my cobra to handle the best it can. Just looking for some help deciding, with or without sway bar. Have coil overs and tubular A-arms now. Most driving will be street for now, maybe race later.
Old 10-11-2006, 05:56 AM
Send a message via AIM to mj_duell
We use and have a modified Speedway bar set too. There is no problem running sway bars with coil-overs if you have a properly tuned suspension setup. Call Speedway and tell them about the car you want to add the bars too. They will ask you specific questions about your set up and recommend the right bars to use.
--Mike / Turn Ten Racing, Inc.
Old 10-11-2006, 04:23 AM
Cobra Make, Engine: CSX4000, 427
Then don't put them on.
Then you probably need to take it to the track, and test it with and without.
"After jumping into an early lead, Miles pitted for no reason. He let the entire field go by before re-entering the race. The crowd was jumping up and down as he stunned the Chevrolet drivers by easily passing the entire field to finish second behind MacDonald's other team Cobra. The Corvette people were completely demoralized."
HTML code is On
