March 2025
1 |
5 |
8 |
12 |
15 |
19 |
22 |
26 |
29 |
30 |
31 |
04-03-2008, 08:23 AM
PA
Cobra Make, Engine: Look-a-like cobra POS
Cobra Brakes -Pedal Feel
What size and type brake system do you have?
How is the pedal "feel".? How is the performance?
Make any changes to increase performance/feel?
Thanks for the feedback.
Bret.
B. Ewing
Advertising
04-03-2008, 11:25 AM
Wilwood pedal assembly, balance beam type, 2 master cylinders, front and rear.
When I first got the car the brakes were terrible, almost afraid to drive it.
After I got the front & rear master cylinder piston sizes right, the balance beam adjusted correctly and I put a set of Wilwood 12.19", 4 piston front brakes in place of the 11" Exploder brakes it stopped as well as it goes..
Dave
Too many toys?? never!
04-03-2008, 12:55 PM
PA
Vacuum assist?
B. Ewing
04-03-2008, 03:02 PM
NJ
I have a Tilton Racing floor mounted pedal set with dual MC's, balance bar and no assist. Fronts are 11" Grenada rotors and Wilwood 4 piston calipers, rears are 11" Explorer. I use the Porterfield R4S carbon kevlar pads. Pedal is nice and hard.
Roscoe
Roscoe
04-03-2008, 03:04 PM
Originally Posted by bret a ewing
Vacuum assist?
no, manual
04-04-2008, 05:18 AM
PA
Thanks Roscoe,
How does the pad compound work for you on the street? I'm looking for a optimal combination of high-performance street and light track.
B. Ewing
04-04-2008, 06:11 AM
NJ
They are the best pads I've ever used. Very grabby, rotor friendly and do not throw dust. I've also open tracked the car a couple of times. They are made for street and track/autocross.
From Porterfield http://www.porterfield-brakes.com/pads.html
R4-S High Performance Street and Autocross
For high performance and heavy-duty street conditions. Perfect for prolonged everyday street use while also being capable of tolerating the most severe street use without any fade. Rotor friendly of course. The R4-S friction level will give you an impressive increase in stopping ability with very minimum pedal effort. R4-S compound has the absolute lowest noise and dust levels, far below OEM equipment or any other high performance brake material. Good for autocrossing, some drivers' schools, and rallies. The R4-S compound is available for virtually any vehicle sold in the US. We also offer the R4-S in pad sizes for competition type calipers that are used under street driven conditions.
Roscoe
Roscoe
04-04-2008, 09:43 AM
PA
SOLD !
(Thanks Roscoe)
B. Ewing
HTML code is On
