SUPPORT OUR SPONSOR
March 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
30 31
  #21 (permalink)
Old 04-15-2008, 07:39 AM
undy's Avatar
Mine's on the front. That's the location to put it on. The fronts typically will see more pressure (depending how your balance beam's adjusted) than the rears.
Dave
  #22 (permalink)
Old 04-15-2008, 08:31 AM
Naumoff's Avatar
Cobra Make, Engine: Unique 427 S/C 427 FE S.O. 484 cu in
Dave
I agree with Dave.
Mine is on the front.
  #23 (permalink)
Old 04-15-2008, 09:12 AM
Naumoff's Avatar
Here is both types of switches from painless through Summit.
http://store.summitracing.com/egnsea...115+4294821076
  #24 (permalink)
Old 04-15-2008, 09:57 AM
The shop that I had install my brake system put in the low pressure inline switch on the rear after the wilwood adjustable purportioning valve. Thats probably why I have to have so much pressure on my brake pedal to get the brake lights to come on. I think I will change to the electrical one that installs on the brake pedal bracket.
Terry
  #25 (permalink)
Old 04-15-2008, 10:12 AM
Cobra Make, Engine: Look-a-like cobra POS
Not for $9.50 to your door step though..
True, although I do trust NAPA products and it shortens my down time.
B. Ewing
  #26 (permalink)
Old 04-15-2008, 10:29 AM
jwd's Avatar
jwd jwd is offline
The nice thing about the mechanical switches is that they never fail (very common with the hydraulic) and if you want to signal the guy behind you to get off your azz, you don't have to actually apply the brakes to turn your brake lights on.
  #27 (permalink)
Old 04-15-2008, 11:43 AM
Naumoff's Avatar
Wrong pedal for that.
  #28 (permalink)
Old 04-15-2008, 01:30 PM
jwd's Avatar
jwd jwd is offline
Tell that to the guy in front of you.
  #29 (permalink)
Old 04-15-2008, 02:09 PM
CHANMADD's Avatar
Motor cycles use a switch that pulls with a spring which would be easy to adapt to any pedal configuration.
  #30 (permalink)
Old 04-16-2008, 05:12 AM
Naumoff's Avatar
If your in that kind of traffic he is too close to see your tail lights and you can give him a friendly wave to back off.
HTML code is On
