  #41 (permalink)
Old 06-24-2009, 12:54 PM
Cobra Make, Engine: Backdraft, 351, 5speed
After 2 coats the only negative I have seen is that dust seems attracted to these polished areas.....or maybe they are just so shiny you can see the fine dust that is on everything anyway.
  #42 (permalink)
Old 06-24-2009, 02:00 PM
FUNFER2's Avatar
As a auto body man, I don't agree with the company saying "they buffed in a substantial amount of the product then painted right over it to disprove the fish eye problem would occur". That to me, is impossible. Even if the car I'm painting has been washed very well, and wiped down with a wax & grease remover, sometimes you'll miss a spot and will get fish eye or other related problems. I have at times, let a small drip of sweat fall on the car and ruined the paint I just laid down. They can't tell me that a bead of sweat is worse than silicone.
So, I don't see how their claim to paint right over it is true. No way,...no how.
  #43 (permalink)
Old 06-25-2009, 05:16 AM
joyridin''s Avatar
yes. efnfast knows everything about detailing and the effects it'll have on your paint. don't listen to anybody. after all, it IS your $50,000 car that might look like crap in a few years, not his.
is the Wet Paint good or bad? use it and let us know. we all need a good test subject. reminds me of that episode of Happy Days where Fonzie uses that toxic waste on his motorcycle seat and it blows up like a balloon.
  #44 (permalink)
Old 06-25-2009, 07:31 AM
Slick61's Avatar
Cobra Make, Engine: BDR #89, KCR aluminum 427 windsor
The previous owner of my Backdraft swore by "Wet Paint", & said he hadn't used anything else on it. When I bought the car, he gave me almost a full bottle of it which, admittedly, I just haven't gotten around to using because I have some paint correction work to do before I get back to applying a LSP (last step product). It doesn't seem to have adversely affected the paint tho... still get compliments all the time.
R. Smith
Santa Clarita, CA
BDR #89- KCR aluminum 427 windsor, TKO-600
  #45 (permalink)
Old 06-26-2009, 12:17 AM
Of course not; my cobra's valed at $100k
All I said is use it if you want, it's not going to disintegrate your clearcoat, but it isn't (atleast from the description and how often I've seen iton sites like autopia) anywhere near the best thing out there.
  #46 (permalink)
Old 06-26-2009, 03:16 AM
CBattaglia's Avatar
Cobra Make, Engine: Gary Edwards Racing 460
Biting my lip.....
Its not the will to win that matters....Everyone has that. Its the will to prepare to win that matters.
  #47 (permalink)
Old 06-26-2009, 04:50 AM
joyridin''s Avatar
Use it. You probably run a better chance of hitting your car with your lawnmower or something off the wall like that and ruining your paint long before this stuff will ruin it.
I just don't understand what is so secretive about the stuff that the manufacturer can't tell you some of it's properties. The MSDS says it has petroleum in it. Like I said...probably similar to Liquid Glass.
  #48 (permalink)
Old 06-26-2009, 05:28 AM
Ron61's Avatar
Post
Just my 2¢ worth. when I had my Cobra I used it from 1996 to 2007 when I sold it and never had any problems with it at all. I use it and other waxes on the 69 Cobra and can't tell much difference in the shine. As for the swirls, if you want a perfect finish then I would have to take mine to a detailer. If you look close out in the sun on the 69, which is red, you can see some of them. But I could also see them on my other car which I only used McGuires on.
Ron 61
Ronnie Widener
View my Miscellaneous Gallery
  #49 (permalink)
Old 06-26-2009, 07:43 AM
Got the Bug's Avatar
Biting my lip.....
Using Wet Paint is no different than using a detailer spray like Meguiar's or Mother's. I bet if we posted a poll, 80%+ of Cobra Replica owners would respond that they regularly use a some sort of detailer spray.
  #50 (permalink)
Old 06-26-2009, 08:06 AM
Slick61's Avatar
Lots of polishes have petroleum distillates in them... primarily the "cleaner" waxes. Helps with tar removal, sap, bird bombs, etc. -another step-saving measure.
R. Smith
Santa Clarita, CA
  #51 (permalink)
Old 06-27-2009, 12:21 AM
Of course, swirls, RIDs, and other micro-marring is caused by abrassion against the clearcoat, almost always when washing/drying/detailing (e.g., quick detailer) the vehicle improperly.....it has nothing to do with product selection (e.g., using Meguiars over something else)
  #52 (permalink)
Old 06-27-2009, 01:49 AM
Ron61's Avatar
I do use the clay-bar on one of my cars and it has the same imperfections in it that the others had. But you have to look close to see them on any of the cars. I am not interested in a perfect finish since I don't show my cars but drive them and 99% of the people that look at them never see the swirls and other small imperfections. Just a couple of painters who asked me what I use and when I told them they said that was a good job for a driven car and me just waxing them and not spending days detailing them. Also there is no way to hide the rock picks and most people seem to prefer that a car be driven to a perfect trailer queen around this area and the shows up North.
Ron 61
Ronnie Widener
  #53 (permalink)
Old 06-28-2009, 12:27 PM
Well, you could always blocksand and re-paint your car every year; that's one way to hide rock chips
Clay bars won't remove any imperfections such as RIDs, scratches, swirls, etc... - infact, chances are they'll actually induce a few because, unless you're kneeding the clay every square inch, you'll induce a bit of marring here and there, it's inevitable (but fine, because you always follow with a polish after a clay anyways) ... all clay does is remove surface contamination, so when you're polishing you're not grinding it down into the paint/pads
  #54 (permalink)
Old 06-28-2009, 01:19 PM
TButtrick's Avatar
ummm.. you're supposed to wash the car first. THEN use the clay bar WITH show shine which includes SILICONE which LUBRICATES the surface so you don't F@#K it up. Good grief.
  #55 (permalink)
Old 06-29-2009, 12:34 AM
Your point being?
It's clay. Clay picks up imbedded ****. Unless you're kneeding it every square inch or two, eventually you're goign to get a piece of **** in it that will leave a micro-marr or two behind until you kneed it into the clay.
I don't care how much lube you use, eventually you will, unless your surface is pretty much clean to start with, pick up something in it which will abbrade against the surface.
And it's a really moot point if your clearcoat is relatively soft - you'll get micro-marring all over the vehicle from just the teeniest bit of dirt getting trapped in the clay.
  #56 (permalink)
Old 06-29-2009, 01:56 AM
Ron61's Avatar
Post
Though I did change and kneed the clay after wiping every few inches I had sprayed, I am just not that worried about a few imperfections in the paint that people have to look hard to see. Besides I now no longer have any cars except my daily driver and it hasn't even been washed in 3 years.
I just never did strive for the perfection that the show car people did. As long as mine looked nice, I was happy. I knew that the next trip out and racing around the track and in the sand and dirt it would be a mess again..
Ron 61
Ronnie Widener
  #57 (permalink)
Old 06-29-2009, 04:24 AM
TButtrick's Avatar
Your point being?
My point being is the one you just made. Wash the car and start with a clean surface. I don't think people who haven't washed or waxed their car in years are the same ones going out and buying clay bars. My car has never seen a conventional wash. Just show shine between clay bar and waxes once a year. Other than the usual road patina, in 7 years and 65K miles, the paint is perfect.
  #58 (permalink)
Old 06-29-2009, 11:56 AM
But no wash will remove all the imbedded atmospheric deposits (dirt yes, but not the imbedded stuff). Hence why you can store you car in a garage, never move it for a year, but wash and clay it a year later and the clay bar will be dirty. Not super dirty like a daily driver, but you're still going to pick up some crap because unless it's in a bubble, contaminents that you can't just wash off will adhere overtime.
I'm sure your paint is in good shape, but I'd be willing to bet $100 if you bring it out into direct sunlight (or use a tool like a sun gun) I can find micro-marring on the paint (such as RIDs and swirls). From your statement I'd be willing to also bet that your car is a lighter color, like a white/silver/yellow/light blue and not a darker on like red/black/dark blue)
  #59 (permalink)
Old 06-29-2009, 03:22 PM
TButtrick's Avatar
OMG.. you're RIGHT! I had a guy in a Corvette that pulled along side my car with one of those "sun guns" and said he'd seen some "micro-marring" on several places on my car!
You know darn well my car is lighter color... duh? Not trying to be argumentative but, why would all the top wax manufacturers and detailers use something that would make your finish look worse than it was? If you have "micro-marring" of the paint from a clay bar or anything else (minimized by use of lube), these are easily filled in with a proper wax afterward. The whole idea is to completely remove embedded contaminants which have a long term negative effect on paint vs micro-marring which is only a negligible visual imperfection. Are you saying this is all marketing hype and we shouldn't use clay bars or are you saying the same thing as me, that you need to do it properly. Here's a guy doing a whole fender on a M6 without folding the clay. I'd fold the clay four times in the same space but note the amount of lube.
  #60 (permalink)
Old 06-29-2009, 10:04 PM
I never said clay baring will make it look worst always - I said it isn't going to improve RIDs or scratches and will probably induce more along the way, depending on how soft the clear is. (e.g., you use a claybar on a daily driven black g35 coupe and the paint, under proper lighting, will look like absolute hell after the claybar, but do the same thing on a corvette, and itwon't be anywhere near as noticeable)
Anyways, to answer your question - simple - because 99% of detailers follow a claybar with a compound and/or polish to remove the RIDs, scratches, and micro-mars. Only time somebody would jump from clay to wax would be if it were fairly new paint (or recently detailed paint), but I'm not certain who would do that since you reall yonly need to clay once every year or two, depending on use.
Filling in swirls and scratches is just half-assed detailing. Proper compound and/or polish to remove them permanently, not just keep covering them up over and over and over. (and then proper care from that point forward to minimize them when they come back)
I'm saying that you need to do it properly, but also that there's no way to have 60k miles on your paint with just washes, clay, and wax, and not have any RIDs, or micro-marring (I'm purposely not writting scratches here because it's apparent that most people seem to think scratches mean stuff like key marks down to the primer) .... even Paul Dalton can't accomplish that feat.
The problem though is people become deconditioned as to what 'acceptable' paint condition is, because most believe that swirls, RIDs, and micro-marring are completely unavoidable and just hte paint aging.
For example, this would be considered acceptable to most people. Yellow corvette, direct sunlight. Hurts to look at with all the RIDs (atleast to me; as I said, most would probably just think the paint is aged)
After polish
