Like Tree1Likes
  #1021 (permalink)
Old 08-15-2009, 04:51 PM
Cobra Make, Engine: Classic Roadsters, 302
When you switched to high beams you were grounding the circuit instead of powering headlights?
  #1022 (permalink)
Old 08-15-2009, 04:59 PM
capteddie's Avatar
Yes! but where?
"the other ed"
  #1023 (permalink)
Old 08-15-2009, 05:28 PM
oh sure now you want to know where? :-) How about at the headlight?
  #1024 (permalink)
Old 08-15-2009, 05:30 PM
capteddie's Avatar
LOL not at the headlights That's what makes this gremlin hunt so interesting.... keep thinking....
"the other ed"
  #1025 (permalink)
onefastmustang's Avatar
Cobra Make, Engine: CRII with a Stroked Windsor
Probably under the hi beam switch if it is the floor based model.
  #1026 (permalink)
Old 08-15-2009, 05:35 PM
capteddie's Avatar
It is a floor based dimmer switch.... but that's not where the problem was
"the other ed"
  #1027 (permalink)
Old 08-15-2009, 05:43 PM
Inside a relay that was being triggered by said switch?
  #1028 (permalink)
Old 08-15-2009, 05:49 PM
capteddie's Avatar
Sorry... no...
This gremlin was so hidden it turned DVs hair 43 different shades of gray. So here's my take on the how things shook out.
So I would turn the head lights on and everything was fine. As soon as I hit the floor mounted dimmer switch and toggle the high beams, we would loose the head lights. Parking and turn indicator lights were fine.
"the other ed"
  #1029 (permalink)
Old 08-15-2009, 05:54 PM
oh.. so it was your highly electric personality that was shorting it out. You were the issue.. LOL
  #1030 (permalink)
Old 08-15-2009, 05:58 PM
capteddie's Avatar
LOL I wish!!! Sadly... It had the same problem when anyone else would hit the high beams.
"the other ed"
  #1031 (permalink)
Old 08-15-2009, 06:19 PM
Cobra Make, Engine: Classic, 347
How about the indicator light.
  #1032 (permalink)
Old 08-15-2009, 06:21 PM
good one... Sadly I forgot about that one. I have no indicator lite on mine yet.
  #1033 (permalink)
Old 08-15-2009, 06:25 PM
capteddie's Avatar
Ding! Ding! Ding! Ding!
We have a winner!!!!
Here's DVs PM to me...
3/32"s of an inch is all we needed or was all that it was taking to ground out! Had the 'socket' been turned left or right that much it would have missed the plate that I had to weld in for the column support!
Moving the plate AND putting a whole new 'Hi-Beam indicator light assembly in place-with clearance.
"the other ed"
  #1034 (permalink)
Old 08-15-2009, 06:31 PM
Motorcity,
ding,ding DING!
Well done!
When I installed the dash the center dash light or "hi-beam indicator" spade, even though insulated with heat-shrink came into contact with the bottom portion of the cowl bar! Ground was severe enough to blow the bulb! 3/32's of an inch in either direction the spade would have missed! At least for now.
Every car I have ever made always had at least one Gremlin" but this one took the cake!
Motorcity, again, way to think it through!
  #1035 (permalink)
Old 08-15-2009, 07:01 PM
Can I trade in these earned stars for future dumb questions?? 'cause I'm a newbie at Cobra builds and I got a million of 'em.
MC
  #1036 (permalink)
Old 08-15-2009, 07:52 PM
Default Door handles and cable.
DV,
When you get a chance could you post up some pictures of the way you attached capteddies door handles and cables including pictures of how you attached them to the bear claw latch?
  #1037 (permalink)
Old 08-16-2009, 05:07 AM
Bear with me on this one-first attempt at posting pics with the Mac.
The first picture is an unmodified handle, the second one is the handle ready to install. I modified the bracket, making a much narrower plate. To install it in the car I cut out a little shorter hole than the bracket, slid the bracket inside the glass, then drilled and pop riveted from the outside- resulting in an almost seamless install.( only the rivet heads show-to be covered by the carpeting.
I attached both ends of the cable by looping the cable through the handle hole one one end and the other end was looped through the bear claw release. Both loops were rigidly attached by crimping normal hardware pinch-lugs ( for the lack of the proper description ?) They are mounted where the book normally mounts the bicycle handles, just a little bit forward.
  #1038 (permalink)
Old 08-16-2009, 06:37 PM
How did you mount the cable sheath in the door jam to keep it from moving when pulling the handle. Is there a special bracket? I have tried using cable ties and the sheath just pulls right through it.
I even tried using pliers to pull the cable tie and it just snaps right off before it gets tight enough on the sheath.
  #1039 (permalink)
Old 08-17-2009, 01:20 AM
Ooops!
forgot about that part........ on the backside of the BRACKET..NOT THE handle I welded a small washer that would let the cable through but not the sheath. In the car already or I post a picture of that-sorry!
  #1040 (permalink)
Old 08-19-2009, 08:30 AM
capteddie's Avatar
Well OK... a little update. Its been pretty quite on the build thread. DV and I have been sticking mostly to email and phone calls while we bolt down the home stretch to get the car done and on the road. We've had a fair amount of last minute gremlins that had to be chased down. Some pretty nasty electrical issues and a fuel delivery issue. All those seem to have been put out of their misery!!!
Now we're waiting on a 4 wheel laser alignment. Only problem is the alignment shop is booked till next Tuesday 8/25. So DV is wrapping everything else up before then. A 4 wheel laser alignment is scheduled for first thing Tuesday. Then the car is off to the upholsters so they can start the carpet install first thing on the 26th. If everything goes as scheduled, I'll pick the car up from them on Saturday the 29th and get it back in DVs shop for the last pieces to go back in. The seats, harnesses and the roll bar.
There is definitely light at the end of the tunnel, but I'm not going to get to excited until I'm in the car and driving.
Here's a check list that DV completed the other day...
PRE-DELIVERY CHECKS
20 Minute RUN: Engine timing reduced by approximately 1.5 degrees-starts immediately without dragging the starter system.
• Wipers– Hi/Lo speed-OK ***
*** wiper off park position–Not working- Switch is a normal aftermarket switch and is not made for a LUCAS wiper motor. (PARK MODE must be done manually.)
• Heater switch: All speeds – OK
• Cooling fan override switch–OK
• Cooling fan automatic on/off control: OK
• Hi-beams:-OK
• Low-beams:-OK
• Parking lights:-OK
• Left turn lights (front/rear):-OK
• Right turn lights (front/rear):-OK
• Brake lights:-OK
• 4 way flashers:-OK
• Courtesy lights:-OK
• Left turn indicator-OK
• Right turn indicator-OK
• Hi-beam indicator–OK
• Hi-low floor switch–OK
• Defroster vacuum control–OK
• Defroster hi speed mode–OK
• Defroster medium speed–OK
• Defroster low speed–OK
• Ignition switch: All functions–OK
Oil pressure gauge (in-dash electrical)–Intermittent, reads zero pressure then shoots to maximum of 100 p.s.i. Then will read anywhere from 30 p.s.i. to 60 p.s.i.
(these readings are the result of the sending unit sticking)
• Engine compartment oil pressure gauge (mechanical): OK
Oil temperature gauge:-OK
• Water temperature gauge:-OK
• Fuel gauge:-OK
• Volt gauge:-OK
• Tachometer-OK
• Speedometer:-OK * NOT TESTED AT PROPER SPEEDS.
(Needs to be cross checked with radar, pace car or timed to check for accuracy!)
• Leaks: NONE NOTED – includes water, oil, rear end, transmission, remote oil filter, remote fuel filter and all lines/connections
• Emergency brakes: - OK -but needs to be checked under powered conditions.
• Brakes: -OK But needs to be bled again!
• Transmission–OK Needs to be road tested.
• Transmission natural safety switch–OK
• Shifter gear indicator–All functions–OK
"the other ed"
