2Likes
02-28-2008, 10:00 AM
MA
Cobra Make, Engine: early Contemporary Cobra (1005), 67 Shelby GT350 with Inline carb on a Boss 302
Contemporary Cobra Watts Linkage
For Doug or anyone interested in adding a Watts linkage to your Contemporary Cobra, I have scanned a couple of pictures and put them in my gallery. The car was one I saw in Carlisle All Fords show several years back. I think it was Ciachi who was a dealer and had made an attachment point that bolted to the stock Jaguar Hub carriers. The billet machined hubs are available, but expensive! This method would get you set up for considerably less, especially if you already have the attachment points. I'm sure Mickmate could fabricate these!
02-28-2008, 12:36 PM
NJ
How about it Nick can you hook us up?
Cobrarich
02-28-2008, 12:43 PM
Yeah, C'mon Nick - make us some toys!
04-15-2009, 08:57 PM
NH
I'll have to pull out the measurements from Dave's car and see what I can cipher from them. I'm thinking if I can make these parts as a kit for you guys which would be easy enough, the real trick would be an installation fixture we can send from car to car with the watts kit. I'll look at it again and will get it done, just don't hold your breath or you'll be the color of Dougs car!
04-15-2009, 09:24 PM
Damn, it only took you a year and two months for an answer. How long will the darn parts take, you slacker?
04-15-2009, 10:01 PM
NH
You can't flog a dead horse to make it move any faster...........Let me see which one of your other projects should I put aside for this one.
04-15-2009, 10:10 PM
You can't die yet, Trigger - there's too much work to do!
04-19-2010, 01:43 AM
WA
Cobra Make, Engine: Contemporary CCX-33711 427 S/O
Anyone know where I can get Watts Linkage parts? I snapped the bolt that connects the machined plate to the hub carrier.
04-19-2010, 04:09 AM
Go to lowe's and look in hardware
Drew I have gotten shoulder bolts from lowe's. The pivot bushing can be replaced if needed. As far as the sphere ends, any chassic shop carry a full line of them. I like and used the greaseable ones with dust covers to keep out debry. I have not really looked into putting a bigger bolt in the pivot. I just carry spares and antiseize the bolt in the carrier. Left twist good drill bit unscrews them real easy. I have the custom uprights in my ERA. Rick L.
04-19-2010, 04:13 AM
Trigger is not dead
767 JOCKEY Doug,Trigger is stuffed and doing well at the Dale and Roy Rogers museum. Trigger has also passed on about 200 trigger#2's Rick L.
04-19-2010, 07:54 AM
WA
Thanks, I'll give that a try
Drew
04-19-2010, 09:10 AM
NH
I have the fixture for the mounting points made. Programming chassis brackets and making hub brackets now. It's all coming together thanks Dave!
04-19-2010, 05:23 PM
WA
Got some exact replacements from Tacoma Screw here in Seattle.
Drew
04-19-2010, 06:37 PM
Nick, mine is up on jacks right now so if you need pics and measurements let me know...... Bob
04-19-2010, 07:03 PM
NH
Hey Bob, I appreciate that. What kind of drawings can you open so I know watt to send? It would be nice to verify it against another car. Isn't it about time you put the wheels on and get it on the ground?
04-19-2010, 07:26 PM
Hey, Rick! How ya doing?
04-19-2010, 07:29 PM
Hey, Nick - if you're going by Dave's any time soon can you snap a few photos of where the E-brake lines tie into the calipers? I'd like to see how they're run, how they attach, and what the hard brake lines going into the calipers look like. Right now just about any way I run the cable the e-brake actuating arms and the cable will interfere with the brake lines. I know that as soon as I see a picture of someone else's setup it'll all come together. Thanks!
04-19-2010, 08:24 PM
NH
Hi Doug, I may have a few pictures of that set up somewhere I'll look for you. I know the Jag e-brakes have the cable come from the side so it has to make a corner in front of the diff or get run through a cantilever.
04-20-2010, 04:15 PM
Registered User
Cobra Make, Engine: Contemporary 427/48 IDA
Hello Gentlemen, kind of new here I’ve been lurking from time to time and seen this post about the Watts Linkage. Long story short version, I have and original jig from Contemporary, mine was a non watts linkage car. I bought the conversion kit, rented the jig (for $200 when I sent back the jig they would send me a complete refund).
The next time I contacted CC I was still in the conversion phase needing parts so I called CC only to find out Peter sold it to a fellow and his mom. (His name escapes me now but I’ll remember it). Ok, bought parts, later contacted them for a refund, they basically told me they are not going to give me a dime.
Tried contacting them again only to find out they went out of business. If anyone is in need I’ll look for it, I doubt I threw it out.
NFS
04-20-2010, 04:31 PM
yes, PLEASE look for it, a bunch of us could use it. I will gladly cover shipping for the unit and make it available to Nick and everyone else with a CCX to use to upgrade our cars.
