Club Cobra SlitherClothing.com
Go Back   Club Cobra > Engine Building, Tuning, and Induction > Weber Tuning
Shelby Enterprises
Shelby Enterprises
Everett-Morrison
Shelby Enterprises
Shelby Enterprises
RaceDeck
Thomas Kirkham Cubic Performance
November 2009
Thread Tools Display Modes
  #1
Old 10-31-2009, 12:48 AM
pmangelos pmangelos is offline
Registered User
Default Fuel Pressure Regulator location
Hi all, I have a question for those of you running Webers. Where did you mount your fuel pressure regulator in relationship to your carbs and fuel pump. I am installing a stroked 351 in a 65 Mustang and have purchased a bypass regulator that I plan on running a return line back to my tank with. My question is do I mount it directly before the first carb, after the last carb, or is it ok to mount the regulator to an inner fender about three feet before the first carb. Any advice is welcome. One more thing, I am using an electric fuel pump mounted near the tank. Thanks for the time.
Paul
Old 10-31-2009, 03:09 AM
Gaz64's Avatar
Gaz64 Gaz64 is offline
Registered User
Paul,
I run a Mallory 3 port bypass regulator.
My system is plumbed splitting the main supply line to the rear carbs, then to the front carbs, then off the front carbs to either side of the reg, then out the bypass and back to the tank on the return line.
My pressure gauge is mounted on the side of the regulator.
My reg is mounted after the carbs as above, with a bypass reg this is the best way, that way the carbs are getting fresh unheated fuel.
Regards
Gary
Old 10-31-2009, 06:49 AM
dlampe's Avatar
dlampe dlampe is offline
Cobra Make, Engine: Kirkham 289 FIA, (sold) RCR GT 40
I agree with Gary. The regulator must go after the carbs. The gauge can go anywhere before the regulator or just mount it on the regulator.
High Maintenance Racing Team
Run & Gun 2003 - 2008
www.runngun.net
Old 10-31-2009, 07:13 AM
*13*'s Avatar
*13* *13* is offline
Registered User
Drivers Side side of engine bay
Hyde D Baker
ERA FIA 2088
Old 10-31-2009, 11:40 PM
Registered User
Thank you all for the replies. One more question if I may, what size lines are you running for the feed and return. I was originally going to run a 3/8" feed line and a 5/16" return line, but in reading the instructions on the regulator it recommends the same size line or larger for a return. What is working for you guys? Thanks Again.
Paul
Old 11-01-2009, 03:17 AM
Gaz64's Avatar
Registered User
Paul, I run 3/8 on both, the bypass sends excess back to the tank,
so at ignition on engine off ALL the fuel is going in a loop back to the tank.
If the return is restrictive compared to the supply line, the fuel pressure may be higher than with the engine running and flooding will result.
Of course it also depends on whether you want your pump running at IGN on to prime the carbs prior to fire up.
You can still have a pump disable (via oil pressure switch etc) at stall condition, ie accident (heaven forbid).
Regards
Gary
Old 11-01-2009, 11:11 PM
Registered User
Thanks to all who answered, I think that I know what I will do.
Sincerely,
Paul
Old 11-02-2009, 07:53 AM
Snakebit Snakebit is offline
I contributed to CC in 2006
Am I missing something here? I thought the regulator had to be mounted between the fuel pump and the carbs, and as close to the carbs as possible. The guage can be mounted after the carbs. If you mount the regulator after the carbs, then how can you adjust the fuel pressure?
The fuel pressure regulator is there to regulate the fuel pressure to the carbs, just under 3 lbs for Webers. You need a return line so the excess pressure can be bypassed.
Snakebit
Old 11-02-2009, 01:32 PM
Gaz64's Avatar
Registered User
A bypass regulator can be mounted before OR AFTER the carbs.
The regulator is not a restriction for fuel flow if after the carbs.
Mounted after, the carbs are getting fresh cool fuel at their inlets,
the regulator dumps the excess back to the tank just like EFI does but at a lower pressure. Mine runs at 3 psi.
Regards
Gary
Old 11-02-2009, 02:33 PM
So if my mechanical pump is putting out 7psi, and I place a regulator, with a bypass set at 3 psi, at the end of my Weber set up, all the carbs will be getting fuel at 3psi??? I would think the first carb would be getting fuel at 7psi???
Snakebit
Old 11-02-2009, 03:07 PM
Gaz64's Avatar
Registered User
Neutral
No, the regulator will send the excess back to the tank.
The pressure between the pump and the reg as seen by all the carbs SHOULD be what pressure the reg is set at. You could fit the gauge at each carb in turn to prove this.
I wouldn't do a bypass reg setup with a mechanical pump since the pump will always be "pumping" unlike when the mechanical pump "idles" when fuel pressure is up.
Regards
Gary
Old 11-03-2009, 08:22 AM
Swanny80 Swanny80 is offline
Registered User
Cobra Make, Engine: Kirkham KMPS 033 FIA 289
I guess I could see with an electrical fuel pump and a bipass regulator it does not matter where you mount it, but for a mechnical fuel pump and a non bypass regulator, the regulator would have to be in front of the carbs to work properly. Wouldn't it? I have a non bypass regulator (mechanical fuel pump) BEFORE my webers and it seems to work fine.
Old 11-03-2009, 10:14 AM
Rick Parker's Avatar
Rick Parker Rick Parker is offline
Registered User
Cobra Make, Engine: NAF 289 Slabside Early Comp Car with 289 Webers and all the goodies
To some extent IMO this whole thing about where to put the regulator is over done. Its all about hydraulics. The pressure is going to be the same throughout the line whether it is place before OR after the carbs. The reason for having the regulator in the first place is to limit the line pressure because the design of the Needle/seat and the mechanical leverage imposed by the Weber design float is not capable of creating a leak free seal when the pressure is much above 3 lbs. There is no "Cushion" at the point of seal as in a Holley because the Needle/Seal assembly is made completely of Brass without any Viton tip (which would be a great improvement), or if the Groose brand (sp?) ball type valve were still available in any size but 3.0.
Old 11-03-2009, 02:05 PM
priobe's Avatar
priobe priobe is offline
Registered User
I have to agree with Rick. I think more importantly the question should be asked, Do I run a return or a dead head regulator.
Majority of the books recommend a dead head reg. however, I am running a return (bypass). There are very few reg. that will operate at 3 psi that are designed for a bypass setup.
I have heard that there is a improvement in perform (night / day difference) with using a dead head regulator. When I was using a dead head by carbs were not properly tuned, so I am have not tested it, maybe that person will chime in to share his results.
I do remember my pressure would creep higher than 3 psi until heat set in than the pressure would lower.
There is a thread on this on CC with this concern. If I remember correctly, this is why I went to a bypass style, along with having cooler fuel circulation.
Old 11-03-2009, 06:41 PM
dlampe's Avatar
I use a non adjustable bypass regulator from Kinsler for my Webers with a return line. It was preset to 3 psi, nothing to adjust. I do disagree(if I understand the conversation correctly) with the flexibility of the mounting location. A bypass regulator must go after the carbs with a return line to regulate the pressure before the regulator and a regular regulator must go before the carbs with a dead head setup to regulate the pressure after the regulator.
www.runngun.net
Display Modes
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
The representations expressed are the representations and opinions of the clubcobra.com forum members and do not necessarily reflect the opinions and viewpoints of the site owners, moderators, Shelby American, any other replica manufacturer, Ford Motor Company. This website has been planned and developed by clubcobra.com and its forum members and should not be construed as being endorsed by Ford Motor Company, or Shelby American or any other manufacturer unless expressly noted by that entity. "Cobra" and the Cobra logo are registered trademarks for Ford Motor Co., Inc. clubcobra.com forum members agree not to post any copyrighted material unless the copyrighted material is owned by you. Although we do not and cannot review the messages posted and are not responsible for the content of any of these messages, we reserve the right to delete any message for any reason whatsoever. You remain solely responsible for the content of your messages, and you agree to indemnify and hold us harmless with respect to any claim based upon transmission of your message(s). Thank you for visiting the clubcobra.com. For full policy documentation refer to the following link: CC Policy
