RaceDeck
Hillbank Superformance
Thomas Kirkham Cubic Performance
Classic Insurance
Classic Insurance
September 2010
Thread Tools Display Modes
  #1
Old 11-03-2009, 11:06 AM
tgitchel tgitchel is offline
Registered User
Cobra Make, Engine: ERA #776, 445 FE
Default Issue with Expansion Tank
Am I missing some sort of spacer, or is the expansion tank supposed to butt up against the distributor cap?
Sponsored Links
Sponsored Links
  #2
Old 11-03-2009, 11:50 AM
rustyBob rustyBob is offline
Registered User
Cobra Make, Engine: 2001 Midstates Cobra Bored 390,auto,340 rear gears,antique bronze in color
no it does not sit against the dist. there should be a thick flange that the thermastat sits in and that helps space it out from the dist.
Old 11-03-2009, 11:53 AM
Registered User
Thanks, Bob.
I figured as much. Does anyone have a part number?
Old 11-03-2009, 12:09 PM
Registered User
thats not a seperate part that i know of it should be made to the tube that the tank sits on.
Old 11-03-2009, 12:11 PM
Jim Holden's Avatar
Jim Holden Jim Holden is offline
Registered User
Cobra Make, Engine: ERA140, ERA 267, ERA GT2038, ERA FIA 2045, ERAGT2077 ERA289ST3001
Which distributor do you have?
Old 11-03-2009, 12:20 PM
patrickt patrickt is offline
I contributed to CC in 2008
I contributed to CC in 2006
Does your tank look like this one from the Gessford site? I'm pretty sure that the ERA ones are not only shortened but spaced out a bit. I think Bob told me that the tanks they have now are made from scratch for them.
Old 11-03-2009, 01:05 PM
lineslinger's Avatar
lineslinger lineslinger is offline
I had the same problem, expansion tank knocking against the MSD dizzy. Ended up making my own.
Old 11-03-2009, 01:15 PM
Dwight's Avatar
Dwight Dwight is offline
Cobra Make, Engine: Lone Star 5.0 / 354 stroker EFI, 402 rwhp & 416 rwtq, TKO 600, YELLOW & over 29,000 miles and a 2006 Mustang GT with new paint and rims
Smile
I had to make one for Lainhart 427 s.o.
Dwight
Old 11-04-2009, 08:27 AM
Registered User
Thanks for all the replies.
I got the tank from ERA. The distributor is an MSD (I got the model number off the Keith Craft web site). I would have hoped, for the price, that it would work without having to fabricate additional parts.
Old 11-04-2009, 08:32 AM
Jim Holden's Avatar
Registered User
It depends on which distributor (ie; narrow or wide) that you got from MSD.
Again, which one do you have?
Old 11-04-2009, 08:33 AM
Although components are reasonably interchangeable you sometimes have to be flexible when performing a build...part of the deal I think. The spacer is relatively easy to fabricate.
Old 11-04-2009, 08:50 AM
Gunner Gunner is offline
My car has the narrow MSD distributor and the ERA-supplied expansion tank, which has a spacer of about 3/8 thickness where it bolts to the intake port. There is about a quarter inch between the lip of the tank and the nearest spark plug wire boot.
The only reason you should need more space is if you're using the wide MSD distributor, or if your intake has an unusually deep inset on the thermostat port.
If it's the former, my 'umble suggestion is ditching the fat-top for a standard configuration disto - the look will be more era-correct and the only real advantage to the wide distributors is reduced crossfire at very high RPMs. As FEs top out at about 6k, you're unlikely to have crossfire problems in any case.
Old 11-04-2009, 11:12 AM
Registered User
Is the narrow distributor taller? I think I will have trouble with my oval air filter bottom plate hitting it as it is. I wonder if short/wide caps with the plugs on the side would fit and solve both problems.
Old 11-04-2009, 12:36 PM
Default It should all fit with the billet MSD Distributor
Old 11-04-2009, 12:45 PM
Registered User
Patrick,
Thanks for the pictures. It looks like you have the same distributor that I have, but your expansion tank appears to have a spacer that mine didn't come with. When I get home I will look through the box again to see if it's in there and take some more pitures. My air cleaner is the long, oval one with Cobra on it that you see a lot. I will need to test fit that next to see how close it comes to the distributor.
Display Modes
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
