December 2024
  #21 (permalink)
Old 12-02-2010, 09:26 AM
mickmate's Avatar
How are you welding it? If you're TIG welding it's worth plugging the ends and filling it with your welding gas to back the weld, then weld it. Makes it much cleaner.
mickmate
http://www.actoncustom.com/
  #22 (permalink)
Old 12-02-2010, 10:53 AM
Senior ClubCobra Member
Yes, I will use TIG. That's a good tip. Thanks Mickmate.
  #23 (permalink)
Old 12-02-2010, 11:22 AM
mickmate's Avatar
A sleeve around it is good insurance for an oil pickup also.
mickmate
  #24 (permalink)
Old 12-02-2010, 03:05 PM
RET_COP's Avatar
Cobra Make, Engine: Fordstroker 408w custom solid roller-Craft ported Brodix 17*heads-CFM ported Vic Jr. intake-1 3/4 primaries- 575hp-TKO-600RR Liberty upgrade- -Moser 8.8 trutrac-McLeod Street Extreme--QA-1-Wilwood brakes, Classic Chambered 3" Cobrapacks, Avon's
Click on my username, go to my public profile and under my car you will see Lou's Pictures. Click on that.
Lou
Lou
  #25 (permalink)
Old 12-02-2010, 04:12 PM
RET_COP's Avatar
Paul, If you use a tubing cutter it won't scatter metal filings in the tube. Then hold one piece vertical ( cut end down) and pull a small rat tail file toward the ground taking the lip off. Holding it in the same position with a pan underneath pour some isopropyl alcohol through from the top which will flush and clean it for weld prep. Do the same to the other piece.
Lou
Lou
