November 2024
Old 11-24-2010, 01:37 PM
Default decking block
What's the factor for milling the intake manifold sides and bottom after decking the block? I hardly found any information on the internet, one guy wrote it's 1.0 for 90° heads and 1.2 for the 80° ones.
So is it in fact 1.2 for the sbf?
Simon
Old 11-24-2010, 02:14 PM
Z-linkCobra's Avatar
Cobra Make, Engine: Everett Morrison, All aluminum small block ford.
How much are you planning on decking the block?
" If it wont break em loose in 3rd gear, it aint enough power "
Old 11-24-2010, 03:50 PM
Jerry Clayton's Avatar
its just over 1.2 but not as much as 1.3
if you can tell me total off the deck surface I can tell you the amount for the manifold surface of the head
Old 11-25-2010, 03:44 AM
I need to take off about 0.03" for zero deck. Further my plan is to mill the intake as the heads are brand new and the block is already bored 0.04 so it's likely the heads will be used on another block during their remaining livetime.
Old 11-25-2010, 11:33 AM
for .030 off deck will require .037 off manifold----that is if they fit together before the decking operation
Old 11-26-2010, 07:07 AM
Jerry, thanks for your help.
How much needs to be trimmed from the bottom of the manifold and the blocks manifold surface?
Old 11-26-2010, 07:14 AM
Cobra Make, Engine: jbl
i'd check the fit before i cut anything, and don't forget to check the distributor fitment also.
