1 |
5 |
8 |
12 |
15 |
19 |
22 |
26 |
06-02-2011, 09:26 PM
Backdraft Racing Dealer
CT
427 (cubic inches) = 7.39393939 US quarts
06-03-2011, 12:21 AM
HI
Cobra Make, Engine: BDR #656 402 SR TW
This thread scares me... sounds like an interesting story
06-03-2011, 05:19 AM
CT
Does not relate to your car Phil... I thought about that later
06-03-2011, 05:26 AM
Originally Posted by Cashburn
Here's another way to ask it... Could you possibly overfill a small block ford by 7 quarts?
Yes..........
Does an 8 quart pan hold 15 quarts?
probably.........
if you were to just keep adding oil to a small block ford engine, I'm guessing you could overfill it by 10 quarts, when you figure the total capacity of the pan and the capacity of the crankcase........maybe more, would it run? that's another question. I'm sure it would start and run for a while, blow by would probably be terrible....
David
DAVID GAGNARD
06-03-2011, 06:41 AM
TX
Cobra Make, Engine: Everett Morrison, All aluminum small block ford.
Originally Posted by DAVID GAGNARD
Yes..........
probably.........
David
Its not the blow by your worried about. Once the oil level gets high enough the crank starts running through the oil. When that happens you will loose oil pressure rather quickly because of all the air in the oil.
" If it wont break em loose in 3rd gear, it aint enough power "
06-03-2011, 06:53 AM
PA
Cobra Make, Engine: Kirkham 289 FIA #690, FRPP 427 Boss engine
History has proven that people can do anything, regardless of how stupid or impossible it sounds, so yes you can. Sounds like someone's old eyes couldn't see the oil line on the dipstick and just kept adding, not even considering how foolish they were being.
RCR GT40 SOLD to Fast 5
Kirkham #690 289 FIA
06-03-2011, 07:25 AM
KS
Cobra Make, Engine: jbl
depends where you put the oil in, and wether the drain plug is in.... that ought to cover all bases.
06-03-2011, 07:29 AM
now onto something important, if you have a Honda lawnmower make sure you check the leve with the dipstick sitting but not scrwed in or you will run it low on oil.
06-03-2011, 08:33 AM
MD
Cobra Make, Engine: BDR #982 w/ Ford Racing 427 Inglese 8 Stack Injection
Off topic but saw someone overfill a 15,000 hp Man BW engine. Standing next to the crankcase doors you could hear the crank web slap through the oil. Made $10 Amsoil a quart look like a drop in a bucket. About 10 barrels to much. So Jay what's the backstory? Huh Huh?
06-03-2011, 09:42 AM
CT
I have to share once I have the time. It is a long one... but it gets more interesting when you only have a 12 quart case of oil, you fill a 9 quart system (that still had about 2 quarts in it after draining to install a temp sender in the pain and seal it) and when you are all done there are still 5 quarts in the case...
06-03-2011, 10:16 AM
NY
Cobra Make, Engine: Backdraft, 302, Tremec 3550. #038
Why is that wrong... you used 7 Qts. to fill it (plus the 2 left in there) is 9. You should have 5 Qts. left from a 12 Qt case, unless to be sure, drop the pan and start from scratch.
Kids in the backseats cause accidents, accidents in the backseat causes kids ! Good reason to get a Cobra !!!
06-03-2011, 12:40 PM
NY
Nevermind just reread it and realized you had to drop the pan to drill it, therefore starting from scratch.
06-03-2011, 01:32 PM
CT
I will tell the tale once the customer is happily motoring along... until then we may have some new excitement. A hard lesson.
