February 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28
Old 09-13-2011, 05:10 AM
Default Paxton Superchargers
Paxton states the optimum CR for their small block ford superchargers is 9.0:1 (like with using the NOVI 1500). Just curious, anyone using a Paxton designed for a stroked 351W (near 427 CID) and with a CR higher than than 9:1, like maybe 10.5:1? If so, how do you like it and did you have any issues with the higher CR? This would be my plan 'B' if I decide to boost and not go the turbocharger rout. My CR is 10.4:1 on a high quality DART 427W build.
Old 09-13-2011, 06:07 AM
PeteF's Avatar
Cobra Make, Engine: ERA2041 sold 2021
I installed a Paxton on my '66 Shelby GT350 mustang, which had 10:1 compression. The Holley carb had to be rejetted slightly richer, and replaced the brass floats with (nitrofill ?) plastic ones to prevent them from collapsing under boost. I had severe pinging on acceleration, and had to add a ping sensor and electronic spark retard box (made by Carter, I think) which retarded the spark up to 15 degrees when pinging was sensed. The boost was only about 5 1/2 psi, but the car was very strong. I always felt I was giving up horsepower by retarding the spark, but didn't want to tear the engine apart to lower the compression. If I had it to do over again, I would build the motor with lower compression, or just stay naturally aspirated. Good luck
Old 09-13-2011, 06:52 AM
Good input, I actually would rather not go forced air if I don't have to. It all boils down to what RWHP I get when all is done. I'm looking for 450 or better at the wheels, if I come in at 400 or less I will probably do something. It'll probably dyno in-between so I'll just have to drive it and see if that will be enough for the cheap thrills. I've got a BMW K1200S sportbike (175hp/530lbs), pretty close to a human cannonball experience - if get anywhere near that I'll be quite happy
Old 09-13-2011, 07:47 AM
Cobra Make, Engine: SPF #298 427 FI
Most of my experience in the supercharger area is in the FI arena. I do know that the vets are 10.5 compression and seem to get away with it. That being said they are FI and the ecu makes the necessary adjustments. Have you considered going with a twin screw type like a kenne bell or whipple?
Old 09-13-2011, 09:05 AM
You need to back timing off as boost goes up. If you quit thinking in terms of vacuum advance and manifold pressure (boost) and start thinking in terms of absolute pressure, then it makes more sense. The lower the Manifold Absolute Pressure (MAP) the more timing you need and conversely the higher the MAP the less timing you need.
The way to run boost on a high compression ratio engine is to cool the air back down, to ambient temp, before it goes into the intake manifold. Compression of air heats it. Superchargers compress air. In addition to the heat of compression, inefficiency of the blower adds heat. It the case of the turbo, exhaust heat conducts into the air charge, as well. An after-cooler is the solution.
If the air temp is too high, the fuel/air charge will auto-ignite on the compression stroke before the ignition spark, called pre-detonation. When this occurs, you may not be able to get off the throttle quick enough to save the engine.
Old 09-13-2011, 01:39 PM
bobcowan's Avatar
The big issue - as stated above - is detonation. Detonation can quickly destroy an engine, is primarily caused by excessive cylinder pressure.
Static compression ratio is only part of the equation. What you're really interested in is dynamic compression ratio; which is a function of static compression, ambient air pressure, altitude, and intake valve closing points. There's a few other data bits, but these are the major ones. You can easily build an engine with 10.0 static compression, and a dynamic compression of 9.0 - which is way too high for pump gas. Or you could build it with a DCR of 7.8 - which is really good for pump gas. So, before building your stroker, do the math and figure out what your max DCR + boost will be.
Along with pressure, heat will really accelerate detonation. You can keep the intake charge cooler by running a little rich, intercoolers, and water/methanol injection. Keeping the timing very conservative also helps.
.boB "Iron Man"
NASA Rocky Mountain TTU #42
www.RacingtheExocet.com
Old 09-13-2011, 02:18 PM
Cobra Make, Engine: SPF #2899 Dart 440 stroker 771 hp w/nitrous
Just a thought...I have a comparable motor - 604.8 @7000 531@4500 torque. I added a 150 shot! It's easy and trouble free....so far!
Old 09-13-2011, 03:53 PM
ECS does vettes all the time with the Paxton, but as stated - in the EFI configuration. I'll give them a call and see what tricks they have up their sleeve. Looked at the Keene Bell and Whipple twin screws, pretty slick. Between the two is there a preferred manufacturer? Both looked like high quality units - seems like Whipple a little better in the customer service department.
Old 09-13-2011, 07:58 PM
gsharapa's Avatar
I did an original Paxton with 750 holley (huge jets) in the bonnett on a Superformance Cobra 351 that had 9.8 compression back in 2001. I used the MSD retard ignition box that retarded the timing under acceleration and also use a fuel pressure regulator that increase the fuel pressure as the Paxton made boost. The Paxton was rebuilt with a bigger disc inside for the 351 as the orignial only put out about 4 or 5 lbs of boost and this one took it up to 10 or 12. Was a pretty cool car back then....Sold it to a guy in Nashville and saw it on Ebay a couple years ago.
Gary
CAV GT40
Old 09-13-2011, 08:42 PM
zrayr's Avatar
Cobra Make, Engine: Fords
Stock timing on my Hi-Po 289 engine is 40 degrees BTDC, stock compression is 10.0:1. With the vintage Paxton I've found it necessary to reduce the timing by just 7 degrees to 33 BTDC to eliminate detonation. In the winter, or when the airt temp is under 70 degrees, I can get by with 36 total timing advance.
Z.
'65 K code Mustang
'66 Galaxie 500
