November 2024
Old 12-23-2013, 06:02 PM
Cobra Make, Engine: SPF GT40
Default Scorpion Roller Rockers
Anyone ever disassemble Scorpion roller rockers? I'm trying to loosen the allen bolts that go thru the pedestal into the head on a Roush crate engine. Even with MAPP gas heat at the head area under the pedestal none of them budge. I sent an e mail off to Roush considering these are only supposed to be fastened to 20 ft. lbs. Any help appreciated.
Old 12-23-2013, 10:42 PM
FWB's Avatar
FWB FWB is offline
valve closed? or open? if there is spring tension it may seem very tight.
Fred B
Old 12-24-2013, 09:29 AM
Thanks. Finally got things loose after learning that the nut needs to be loosened, not the allen bolt.
Old 12-24-2013, 12:13 PM
FWB's Avatar
FWB FWB is offline
OOPS! yes the lock needs to be broken loose first. i assumed you knew that.
Fred B
Old 12-24-2013, 01:02 PM
Cobra Make, Engine: SPF #1019
Why are you removing them?
Old 12-26-2013, 09:53 AM
Leaking head gasket. Heads also need cleaning and intake valve stems look like oil is getting sucked past seals. Haven't disassembled valves yet to check guide wear.
