February 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28
Like Tree7Likes
  #61 (permalink)
Old 06-27-2016, 06:40 PM
Gaz64's Avatar
.040 is a good compromise gap for a street strip car.
I would perform a fuel volume test at the last point prior to the carb, into a bucket.
Run the pump for 30 seconds and record the volume the collected.
If your 3/8 lines are aluminium, they may be restrictive due to their wall thickness.
Gary
  #62 (permalink)
Old 06-28-2016, 07:51 AM
Texasdoc's Avatar
Cobra Make, Engine: Lonestar Classics LS427. Self-built 408W, AFR 195 heads, Performer RPM Intake, Quick Fuel 750, 407rwhp, 479rwtq
No Joy....
Increased fuel pump pressure. Increased the secondary jets from 82 to 86. Still starts missing after 4500 rpm. After letting off the throttle when it started missing, it backfired thru the pipe.
I think I'm going to either take the heads off and get them checked, or just take it in and let someone else fix it. Anyone know a good "hotrod" mechanic with a dyno in DFW?
  #63 (permalink)
Old 06-28-2016, 08:03 AM
Make sure you don't have a leaky header gasket....
Broken valve spring should be easy to spot, otherwise, I can't think of anything else that would warrant pulling the heads.
Lykins Motorsports, LLC
www.lykinsmotorsports.com
www.customfordcams.com
brent@lykinsmotorsports.com
  #64 (permalink)
Old 06-28-2016, 08:09 AM
bingo2's Avatar
Cobra Make, Engine: RUCC, SB 331 Stroker
This has been an interesting thread to follow with the many comments and suggestions regarding the fuel supply. Clearly, you don't have a fuel related issue. It has to be ignition or mechanical related. I'll make one more suggestion; I think you mentioned that you have a new coil installed, even new ones can be defective. Before you start to disassemble things, if you have a known good one lying around, swap it out and see what happens. It only takes a few minutes.
  #65 (permalink)
Old 06-28-2016, 08:23 AM
Very good point....I had a new Mallory coil take a dump on me once. Symptoms were a lot worse, but anything can happen.
I would try that before you tried anything else.
GLS-BDR226 likes this.
  #66 (permalink)
Old 06-28-2016, 05:40 PM
Texasdoc's Avatar
I am using a TFI style (square) coil left over from when I had the EFI. The one I am currently using is a new MSD 5527. I had a Mallory coil fail on me and the MSD 8227 gets terrible reviews. I have a used Ford TFI coil out of an old mustang that I can try.
Does it matter that I am using a TFI style coil instead of a round style coil with the carburetor? I wouldn't think so since my Mallory HiFire box instructions said to use the Mallory square coil in the first place.
  #67 (permalink)
Old 06-28-2016, 07:15 PM
fastd's Avatar
Cobra Make, Engine: ERA FIA, 351W
did you regap the plugs?
  #68 (permalink)
Old 06-28-2016, 07:17 PM
Texasdoc's Avatar
I haven't yet. I will tonight while I'm changing the coil. I was at .040 for months and it was still missing then.
I'll also put the secondary jets back to 82. No exhaust leaks - just redid those with Percy's aluminum gaskets on the headers and new collector gaskets.
  #69 (permalink)
Old 06-28-2016, 10:21 PM
CHANMADD's Avatar
.. I have been having the same problem ..changed .wires and just waiting for new coil,cap,rotor,and module
  #70 (permalink)
Old 06-28-2016, 11:12 PM
Texasdoc's Avatar
Re-gapped the plugs - all now at 40 again. Went back to 82 on the secondary jets. Still at 6.5 on the Primary PV. Changed the coil. Tested the resistance of the wires - all uniform. Took off the valve covers (again), disconnected the coil lead, and spun the motor with the starter a few revolutions. All rockers/valves going up and down without any problems or apparent errant noises - so I guess no broken springs.
Now it's midnight in Suburbia so I couldn't test it. We will see what tomorrow brings. Still haven't been able to install the WBO2 gauge. Maybe next week if it doesn't run with the replacement coil.
Question still open - does having the square (TFI) type coil matter?
cdnus likes this.
  #71 (permalink)
Old 06-29-2016, 05:05 AM
fastd's Avatar
I did a search for "high rpm miss" - a lot of people with similar issue. Several reasons - seems like most were problem with distributor.
  #72 (permalink)
Old 06-29-2016, 05:47 AM
Just as an aside....
A broken spring can still let a valve go up and down. If it's cracked or broken, it will let the valve float because the spring pressure is greatly reduced.
I'm of the mind that it's ignition too, but I'm trying to cover all bases.
  #73 (permalink)
Old 06-29-2016, 06:17 AM
Jac Mac's Avatar
Cobra Make, Engine: DIY Coupe, F/T ,MkIV.
A quick check to eliminate the ignition... Hook your timing light up to the HT Coil to Distributor lead, tape the trigger/button to the on position and zip tie it in a position where you or passenger can observe when you run it up thru the misfire zone , strobe light should be virtually continuous, any uneven gaps in the strobe flashs show an ignition fault, if thats all good then you can concentrate on the jetting etc.
Jac Mac
  #74 (permalink)
Old 06-29-2016, 09:51 AM
Texasdoc's Avatar
New gaps, new coil, return to old jets, same old problem.
Will try the timing light and/or see if I can find a rental distributor.
  #75 (permalink)
Old 06-29-2016, 10:12 AM
Cobra Make, Engine: LSC
Send a message via AIM to cgsincc
What kind of distributor do you need?
  #76 (permalink)
Old 06-29-2016, 10:21 AM
Texasdoc's Avatar
Anything that I can use to put in this 408. Basically a 351W distributor with a steel gear. I have the 6AL box but that can be temporarily disabled. Right now I have MSD 84781 without the vacuum hooked up.
  #77 (permalink)
Old 06-29-2016, 12:03 PM
I'm ordering parts for a Windsor build. Email/text me your address again and I'll have an MSD distributor drop shipped to you. When you're done with it, just ship it to me. It will have a steel gear on it.
dcdoug likes this.
  #78 (permalink)
Old 06-29-2016, 03:51 PM
Ok, it left today from the warehouse.
  #79 (permalink)
Old 06-29-2016, 05:03 PM
Gaz64's Avatar
That's some beautiful service.
  #80 (permalink)
Old 07-02-2016, 04:23 PM
Texasdoc's Avatar
Maybe.... Still trying to hunt down the cause of this. Waiting for the dist Brent sent.
While waiting, I decided to go back thru and check everything again. Even though everything has been checked, why not? Plugs gapped. Spark lead ohms good. Fuel pressure, timing, etc.
I pulled out the old/destroyed MSD cap that I used to set the rotor phase to check it again. Hooked it up and started the motor. Everything looks "in phase" but the spark is barely visible. Hmmm, weak spark.
Put the new coil back in (had replaced it with an old one for testing) and it still had weak spark. Since the plugs are good, wires good, coil good, lets check the Mallory Hi Fire box (6AL copy).
It gets 13 volts on the big red wire (I also have the MSD capacitor on this line to prevent spikes). 13 volts on the small red wire. Ground is good.
Somebody make sure I did this right:
1. Disconnected the coil lead at the distributor, put it 1/4 inch from ground.
2. Disconnected the Green/Purple wires at the distributor.
3. Ignition On, Engine off
4. Short the Green/Purple wires with a paperclip. NOTHING.
5. Disconnect the Green/Purple wires at the connection at the box (I have the MSD shielded cable as an extension). Short these wires - NOTHING.
6. Cut the connector off the Green/Purple wires so I only have a few inches of wires going right into the box. Short these - NOTHING.
7. Touched the white (points) wire to gound - BUZZ. Big spark. Nice loud buzzing.
So, it appears the magnetic pickup input to the Mallory box is dying/dead. Did I do anything wrong in the testing? There is not a switch to tell the box magnetic vs points.
Any other thoughts before I go buy a new ignition box?
