December 2024
Like Tree13Likes
  #21 (permalink)
Old 10-11-2016, 09:34 AM
Originally Posted by YerDugliness View Post
Here is some info on tuning webers...I don't think it's the same as the CD, but I haven't found that yet.
Weber Tuning Tutorial - On YouTube - GT40s.com
When I mentioned the GT40s forum, I wasn't referring to the GT40s board on this forum....go to: GT40s.com - Powered by vBulletin
Here is a thread on our CC forum regarding tuning webers...you've probably already seen it, but I thought it might be worth mentioning.
Weber Tuning - Club Cobra
I'll keep looking for the CD on the GT40s forum, will post on the induction forum at GT40s asking about it.
Cheers!
Doug
That would be great to get a copy of the CD. The resolution on YT isn't great plus I could refer to it without having to go through YT when I want a reference.
1985 CCX likes this.
  #22 (permalink)
Old 10-11-2016, 10:20 AM
YerDugliness's Avatar
Cobra Make, Engine: Cobra Auto Works body, Ron Godell Racecars chassis, 1989 Mustang GT 5.0 HO (converted to carb), W/C T-5, 3.73's in a Ford 9" Traction-Loc.
I should have read the post on GT40s...the YouTube video is in 3 parts, and it is the complete contents of that CD.
I'll ask on GT40s if it's possible to get a CD. If not, perhaps breaking the CD down into three tutorials would help.
Cheers!
Doug
YD,E./PNB
No names were changed to protect the innocent!
  #23 (permalink)
Old 10-11-2016, 12:59 PM
Here's the primary source...DUUUUH, I REALLY should have read the info on the posting on GT40s...DUM-DUGLY!
"The company that produced the video, Fast Freddy's, is still in business despite reports to the contrary. Mike got permission from Freddy to allow us to post it on Youtube, sent me his DVD, and I was able to upload it to YouTube."
...no idea who "Mike" is...
Hope this helps.
Dugly
YD,E./PNB
Last edited by YerDugliness; 10-11-2016 at 01:30 PM.. Reason: forgot to add the contact info...DUUUUH!
  #24 (permalink)
Old 10-11-2016, 06:16 PM
Gaz64's Avatar
Some good info on that 3 part video, have seen it before.
I would like to see some more on idle jet selection (air bleed orifice, and fuel), emulsion tube selection etc.
Gary
  #25 (permalink)
Old 10-11-2016, 08:26 PM
Jim Inglese is your guy, then...perhaps he will know of other publications that will have that detailed info. As I read the first part of the 3-part series it seemed to me that the Webers might be simple to work on and the combinations of various parts helps with fine tuning. Sounds like a set of flow-meters is probably in your future if you want to do your own builds.
Good luck...
Cheers!!!
Dugly.
YD,E./PNB
  #26 (permalink)
Old 10-12-2016, 04:23 AM
Gaz64's Avatar
They are extremely easy to work on.
An 8 year old would have no trouble, but give him a WCFB or a Quadrajet, and there may be some tears.
The art for Webers is parts selection to suit the engine.
Idle fuel and air is easy, but emulsion tube is bit more tricky.
Hence the absolute critical importance of float level settings.
PS. My Weber, Holley, Carter, Edelbrock, Rochester etc etc library and spares/tools etc is always growing, .
Gary
  #27 (permalink)
Old 02-18-2020, 12:14 PM
BigGuy's Avatar
Cobra Make, Engine: CSX4xxx, Alum. Shelby 427 w/ Webers,
Default Weber carb and engine rebuild
Doing a complete rebuild on csx4xxx aluminum Shelby 427 with 48ida Weber’s.
Had the carbs sent to Jim Inglese ( he amazing). They look great!!!
First problem before rebuilding
1) was fuel pressure way to high 5-8
2) had manual fuel pumps and electric ( that’s how it came from Shelby dealer)
3) custom cylinders and new cam should improve power range.
4) was bogging around town or after resetting bogging over 60.... than should go away now.
I’ll update went I finish up in the next few weeks.
Thanks,
Jon
  #28 (permalink)
Old 02-18-2020, 08:16 PM
CompClassics's Avatar
Cobra Make, Engine: SAI FIA, 289HP (5-bolt), 48IDA Webers
Is the problem fixed now?
  #29 (permalink)
Old 02-24-2020, 03:30 PM
BigGuy's Avatar
Went for a drive this afternoon to breaking in engine/ carbs/ brakes.
This engine is so smooth now....what an improvement!!!
Went with a new fuel regulator and keeping pressure around 2.5 to 3.0 much better no bogging. Not using manual fuel pump and just going with electric ( disconnected “ reserve” pump too).
More later
Thanks,
CompClassics likes this.
Jon
  #30 (permalink)
Old 03-02-2020, 11:41 PM
cobra's Avatar
Cobra Make, Engine: ERA 427 SC # 571, 472 Shelby aluminum "stroker " CSX # 299 from Gessford, 48 IDA Weber carburetors from Jim Inglese
Hello Peter
Check if your Webers have 3 drillings. Mine ran much better afterwards in daily traffic (0 - 3';000 min-1).
If possible mount two Lamda sensors, then you can see what your mixture is doing.
Good luck and much patience
Tom Kirkham likes this.
Greetings from Switzerland
Walter
http://www.kreuchi-auto.ch
  #31 (permalink)
Old 06-21-2020, 06:44 AM
Default My next mod
I wrote a couple emails to Jim Inglese yesterday requesting hyd roller cam advice and 48IDA + manifold vertical dimensions. My current 408W setup is a solid roller cam and too radical for decent country backroad driving. The trailer hitching on mountain switchbacks is annoying.
I've always wanted a set of downdrafts and I'm scrapping bottom finding things to do on the car.
So next will be new cam,valve springs,lifters, rods, chain. Once running again I'll dive into the Webers.
  #32 (permalink)
Old 06-21-2020, 03:17 PM
1795's Avatar
Good luck, will be interested to hear what you decide on. Weber's can be touchy on the road, going with a less aggressive cam may help. In a race application they work great, but then again I am never below 4,000 rpms except when going through the paddock to and from the grid.
  #33 (permalink)
Old 06-23-2020, 05:12 PM
After searching the GT40 forums I came across info on the Inglese cams that Comp Cams makes. (same family of companies now). This 2012 catalog lists them and quite a few Weber accessories. All still available but not listed in the 2014-2020 catalogs.
I think Jim Inglese got all the Webers sales back it seems.
http://www.efisupply.com/images/fast...12-Catalog.pdf
I'll probably go with the 35-491-8 hotter of the two offered in the 5.0 firing order. Still sold thru Jegs etc... Still need to pull my cam and get the PN to see if I will have clearance. (My PN is unk to me and no cam card).
  #34 (permalink)
Old 06-23-2020, 08:39 PM
Gaz64's Avatar
I would hope those cams are listed as lift at the lobe, not "valve lift" as quoted.
Gary
  #35 (permalink)
Old 06-24-2020, 03:51 AM
LOL, yea those would suck for sure. I 'd be better off with an RV cam.
With my 1.6 rollers I'll be at .571 and .565 at the valve.
