November 2024
Like Tree2Likes
  #21 (permalink)
Old 01-26-2021, 02:22 PM
Gus M's Avatar
Cobra Make, Engine: BDR Iconic 427 (Dart SHP-Ford 351W)
In reading each and every post with earnest attention, and I thank you all for that, it appears that the most common, safe and sensible decision is to go with the SR.
My Ruby Red Backdraft has an Iconic 427 and I really like it. It does exactly what I want it to do. Drive around town and take long road cruises. In comparing the 427 Iconic specs with the SR, there are many similarities.
rodneym's hit it on the head when he wrote: "Everyone says get the SR. And the buyer always gets the R - can't help themselves."
I've been warned but...I can't help myself. Going with the R.
I'll share my review when I get the car with that nasty Roush 427 R.
Thanks for all of the input.
  #22 (permalink)
Old 01-26-2021, 04:51 PM
rodneym's Avatar
Full Blown Member
Premier Contributor
Yup.
I knew it.
All we need now is Patrickt to whip up an "I told you so" for me (I'm too nice).
rodneym
  #23 (permalink)
Old 01-26-2021, 06:20 PM
Originally Posted by rodneym View Post
Yup.
I knew it.
Naaah, I've mellowed in my old age.
  #24 (permalink)
Old 01-27-2021, 08:20 AM
Ok, I’ll say it.
You’ll be sorry you didn’t get the SR.
Jim
  #25 (permalink)
Old 01-27-2021, 03:52 PM
saki302's Avatar
Cobra Make, Engine: Superformance Mk3, Roush 427
Mine came with the R. I'd likely prefer the SR, but I drive this car for fun, so I dont mind revving it out a bit more before shifting.
If I did supercruises with the scof crew, the SR would be much more pleasant to drive (and a 650 RT aed carb vs the 750).
  #26 (permalink)
Old 08-02-2023, 12:55 PM
Cobra Make, Engine: Midstates 427" Stroker Smallblock with Trick flow heads
The best of both worlds would be to build using a smaller higher velocity port that flows as well or better than the R in the .200-.450 lift ranges and port the intake manifold to excced the flow of the heads. Combine that with a smaller cam in the 235I/242E range and you will make near equal top end power to the R with a flatter less peaky torque Curve. Even if the engine seems Under-ported for racing, big cube motors have no trouble drawing harder than the simulated flowbench depression so power doesn't suffer anywhere nearly as bad as many would imagine.
so....I would be tempted to run the SR but run it with a ported (tapered) single plane intake manifold in order to extend the powerband and improve the peak power even with the smaller cam....and this can be accomplished without negatively impacting part throttle or low speed drivability.
The Roush motor has a very carefully selected combination of parts and is guaranteed it will hit the advertised numbers. But that said it is (for want of a better word) still a "crate" motor, so there will be little to no consideration or attention given to massaging the ports for enhanced flow as with a custom engineered combo. A bigger cam will act smaller and come in sooner by advancing the intake centerline 2 to 6 degrees in order to trap more cylinder pressure (dynamic compression) at lower engine speeds.
I've made between 25 and 40 horsepower from just porting the intake manifold, I would go with the SR and probably look at doing just that.
The smaller the cam is that will get you to the desired HP goal will almost always give you the highest average torque and part throttle "linear" responsiveness....and torque is what you feel at part and roll-on throttle.
Opinions vary, but you don't drive an engine on the street the way you load it on either an Engine or a chassis dyno. A cobra will accelerate faster than the standared 300 rpm per second an dyno cell loads the engine. And as a result, Most cobras will easily blow off the tires if you apply the power too quickly anyway. So build it for tractability and part throttle responsiveness, so you can tune your driving skills to the car and more easily/predictable apply power to the track.
My own 427 I believe accomplishes this very thing, Roush SR type drivability with R Type peak power, It idles with a nice chop at 800-850 RPM, never loads up at idle, Cruises on the highway smoothly at under 2000 RPM and makes over 500HP. And I can promise you no-one who'se ridden in it ever felt like it lacked for horsepower or face ripping torque in any gear. Optimizing the port velocity and cross section is the key to a great combination.
The joy to me of a big torque motor is the pleasure of having grunt and acceleration in any gear virtually everywhere in the powerband, if I added 100 hp (and I could with a bit more cam and head flow) and 1000RPM to the power peak the car would ET quicker but I doubt it would be anywhere near as fun to drive. To me it makes very little sense to take a big engine and cam it where it's only happy at engine speeds higher than a light nimble car really needs it to be.
to me the best combo would be a 357" big bore 8.2" deck (4.185B x 3.25" stroke) high rpm capable engine with modestly sized turbos that would give you a nice linear boost curve so it feels exactly like a big block off idle though 5500 rpm but keeps boosting all the way to 7500.
Wize
