April 2025
6 7 8 9 10 11 12
13 14 15 16 17 18 19
20 21 22 23 24 25 26
27 28 29 30
Like Tree32Likes
Old 03-23-2022, 09:46 AM
Smile 7500 RPM 302 Stroker Suggestions
Hello!, As the title says I'm looking to build a 302 Stroker capable of 7500+ RPM at 450ish horsepower. The car will be used occasionally on the track, for autocross, and spirited driving on street come weekends. I've never built an engine on my own before, let alone something like this so I was hoping someone here might have some information/experience to help point me in the right direction. Money isn't an object as I'm looking to do this right the first time.
As for right now, I was looking at using Ford Stroker's 331 Liberator Dart Shortblock for the bottom end, with the Scat Cranks and Rods(or should I upgrade to the Callies magnum crank+ Oliver light rods?), flat top pistons, and the inline valve relief. For heads, I was looking at Stage 2 Canfield 192 cc with 58 cc combustion chambers, paired with Ferrea intake and Mahle exhaust valves, beehive springs, and titanium retainers. I am still unsure what style of camshaft, lifters, intake, or what compression ratio I'd I'd like to run (Suggestions are welcome).
Are these the right parts for the build/could they theoretically handle 7500+? I'm worried I might need a lighter rotating assembly, and with the pistons working with the Canfield heads. If anyone has used Ford Stroker and CPR I'd also be interested in hearing about it.
OR
If anyone has an engine builder they could recommend, I'd consider going that route instead.
Thanks!
Old 03-23-2022, 10:17 AM
eschaider's Avatar
Why are you choosing a 302 displacement and why is a 7500 rpm operating speed important to you?
Pete Munroe and sgianino like this.
Old 03-23-2022, 11:06 AM
Trans am inspired build, those are about the numbers they hit back in the day.
Old 03-23-2022, 12:18 PM
Cobra Make, Engine: ERA#134 427 Ctr oiler 2x4's
Just talk to Brent Lykins and be done with it. He can help you with all the things you mentioned or even build the motor.
Tommy, 55312, Sawdust and 2 others like this.
Old 03-23-2022, 12:22 PM
eschaider's Avatar
The metric that moves these cars and makes them fun to drive is torque. Unless the engine is supercharged the 302 displacement is going to be a little light in the seat of the pants dyno space. This usually results in a new and larger engine or a new car purchase.
That said, it is worth noting that the all conquering Cobra legend was created with 289 inch engines. It is also worth noting that, that was then and this is now.
With the availability of aftermarket everything for the Windsor platform there is no reason you can not produce a very frisky 427 (or larger) Windsor engine for your car at essentially a push price wise. Visually they can be indistinguishable however the moment you let out the clutch on the big inch version you have an extremely different experience.
The old TransAm legends and performances were great on the track but not so much on the street. The large port heads ran like crazy upstairs and were not as well suited to the proletariat style of driving that non track days enforce on us.
In the end this is your call exclusively. That said you did solicit opinions. I suspect others will also encourage you to explore a larger displacement alternative before this thread is over.
Winchester67 and MKS427 like this.
Old 03-23-2022, 12:30 PM
eschaider's Avatar
Neutral
Follow on thought,
Most new Cobra owners will be wowed by the car performance and behavior, irrespective of which engine is in it. As you begin to get acclimated to the car you always wish you had built for more power because you become accustomed to what the engine can produce — one more thing to think about.
Pete Munroe and hauss like this.
Old 03-23-2022, 12:45 PM
The question I would ask is do you want it to be 302ci or do you want a dimensionally the same size as a sbf....(8.2 deck/ 9.5 deck)?
I went with Brent Lykins and got a 8.2 deck block but its an aftermarket block (4.125 bore)....363 final cubic inch. Can spin to 8k.
Rpms is mostly about valvetrain stability.....needs to be light....will cost money, a good bit.
Old 03-23-2022, 12:47 PM
Tommy's Avatar
bapapp15,
If you know the pluses and minuses of living with such an engine and you're willing to tolerate its shortcomings on the street, then Brent Lykins can build it. But I urge you to pay attention to those who have learned what its like to live with a race engine the hard way. Generally speaking, engines optimized to operate up to 7500 RPM are not much fun below 3500 RPM, which is where you'll be 95% of the time on public roads. More than a few hotrodders have paid a lot of money for engines that are more fun to brag about than to drive.
eschaider, Alfa02 and Harpoon PV2 like this.
Tommy
Previously owned EM Cobra
Old 03-23-2022, 01:11 PM
twobjshelbys's Avatar
Originally Posted by Tommy View Post
bapapp15,
Generally speaking, engines optimized to operate up to 7500 RPM are not much fun below 3500 RPM, which is where you'll be 95% of the time on public roads. ...
Agreed. I found that the engine wasn't happy running at lower RPMS and spent much of the time in lower gears at higher RPMs - 3rd most of the time on the street. It just felt like the engine was asking me to blow the cobwebs out.
Harpoon PV2 likes this.
CSX4005LA
Old 03-23-2022, 01:54 PM
Grubby's Avatar
Cobra Make, Engine: ERA 838
I suggest discussing your wants and needs with a good engine builder and getting suggestions. I used Brent Lykins who frequents this board.
He asked lots of questions about how I planned to use my Cobra and built to match.
He could sell you parts to build the way you want or build for you.
Old 03-23-2022, 06:37 PM
eschaider's Avatar
I think the OP will be OK. As long as he uses a good set of 5.57 gears in the back and keeps his daily driving rpm between 5500 and 7500 rpm this is likely to be an engine for the ages.
Gpfarrell likes this.
Old 03-23-2022, 10:29 PM
Thanks for all the suggestions!, I'll get in touch with Brent shortly.
Old 03-23-2022, 10:41 PM
Harpoon PV2's Avatar
289 Cobras were quoted as having 271hp at 6,000rpm and 312lbs ft. 3400rpm on 11.00 compression! You can buy a 5,0L cast iron roller rocker engine with 9.0 compression that is advertised as 300hp, not sure what rpm, but I am sure high enough! This is at Summit, but pretty much all the good builders can meet that. Funny note, after the 1965 FIA Class III win, Alan Mann talked about how much he hated the 289, because it broke when pushed above 6,500 rpm. He went on and said, "it was a lousy engine, the 289, and basically unreliable, though $250,000-worth of development would have made it a world-beater." I think if he should have added another zero, that's probably what Ford spent to make the 302 into one of the best engines of all times!
One last note, I have never meant anyone who drove a small block Cobra in the 60s or 70s who looking back complained about the lack of power, that includes me! We all just smile with that far away look of someone remembering their first love! Cheers, Dennis
Old 03-25-2022, 05:13 PM
xb-60's Avatar
Originally Posted by bapapp15 View Post
.....I'm looking to build a 302 Stroker capable of 7500+ RPM at 450ish horsepower. The car will be used occasionally on the track, for autocross, and spirited driving on street come weekends.....
To the OP, I quite understand where you're coming from here. The original 260 and 289 Cobras race cars, and to a lesser extent, the small block street roadsters, had high revving engines with an emphasis on top end power. What's wrong with wanting to emulate that in a replica small block Cobra build? Sure, it won't have a lot of torque in the low and middle rev ranges, but if the power is there at the top end - and that's what the owner wants - what's the problem with that? If it's a bit flat in the lower rev range, it had compensations at the top end. What's a nice shifting gearbox for anyway?
In my own original engine planning, and before the reality of what was able to be road registerable where I live became clear to me, Brent Lykins and I exchanged many emails regarding engine specs. I wanted an engine that would develop max power at around 7500rpm and the bottom end torque didn't particulary matter. Very light car....small, high revving Windsor ....I didn't see a problem. If I was able to do that legally, that is still what I would want to be doing. Anyone can have an engine with plenty of low down muscle, but that's not what everyone wants, and it's not what the original small block cars were like.
Cheers!
Glen
Buzz and Tremelune like this.
Old 03-26-2022, 05:03 AM
Buzz's Avatar
This is spot-on within the context of this thread. If we're talking about small block Cobras, don't forget that they weigh a bit over half of what the average '60's / '70's American muscle car does and the addiction to big-inch, big-torque, low end luggers originated with the need to make these behemoths get up and move in a similar fashion to "true" (read that "smaller/lighter") sports cars; generally of the European persuasion, that satisfied generations of drivers using much smaller, higher-revving engines.
"Move" in the preceding sentence means only in linear terms, because no amount of torque and low-end grunt could overcome the laws governing changes in direction of a massive object rolling on skinny, bias-ply tires. The little sports cars were still plenty of fun and generally faster on any road that wasn't dead straight and 1320 feet long.
Having said all of that, the OP never said that this engine was going into a Cobra. "Trans Am inspired build" implies to me he may be thinking about a Mustang but even if that's the case, a Trans Am inspired 1st gen Mustang gutted for racing performance would still be a relatively light car.
Tropical Buzz
Old 03-26-2022, 06:48 AM
MKS427's Avatar
Cobra Make, Engine: FFR MkIV 427
408 stroker is a great budget build, without going to a Dart block. You can build it for torque and reliability for a reasonable amount of $$$. For an extra 3-4K you can go with a Dart 427/445 at sub 600 torque.
Someone mentioned using B Lykins or others. My 2 cents, known engine builders will have the experience to know the package works, will do it for less $$$, and will include a warranty on just about anything that runs on pump gas.
Old 03-26-2022, 06:51 AM
MKS427's Avatar
Follow up: IMHO, If you go with a 7500 rpm street engine it will better suited for the track than the street. With 7500, you should invest in T&D shaft mounted rockers, $$$$$$$.
Old 03-26-2022, 08:46 AM
eschaider's Avatar
The majority of car owners on this site do not have 289 powered cars. Their engines range from 400 to about 500 cubic inches and larger for a reason. While the idea of a small displacement high revving engine possesses a certain romantic aura and tug on our heart strings, the simple fact of the matter is the vast majority of the car owners opt for displacement increases so they can enjoy that solid kick in the seat of the pants that is so intoxicating, at almost any speed.
There is one site member that used an FR500C Ford competition engine for his first car. The engine could easily exceed 7000 rpm by a wide margin and it made somewhere between 450 and 500 hp. After two or so years he sold the car and built a new car this time using a 482 inch FE for power.
The romance of the all conquering, high performing small block 289 of years gone by, has gone by and for good reason. Today there are better alternatives for the non competition driven replicas we all have today. The preponderance of the owners have voted with their wallets and the winner was larger displacement lower rpm engines which by the way require less maintenance to maintain those performance levels. By the way I believe the highest performing racing creation on the site here is Morris' 427 FE powered Kirkham which I believe uses a 482 inch FE.
In the end it is your car and your money, which makes any decision you make correct at the time you make it. However, just like so many who have had that same gleam in their eyes for the romantic small block that revved so high and won everything in sight a half century ago, you need to remember that was a factory backed, factory maintained effort a long time ago. Today we have even better alternatives available to us that make much more financial and performance sense.
Old 03-26-2022, 05:15 PM
I'm sorry but i'm a realist.
It doesn't matter what we do to our cars trying to be purists.
We can't outrun a teenager with a chipped Mustang bought by mama?
We do look way cool though.
spf645 and Harpoon PV2 like this.
Old 03-28-2022, 12:05 PM
CHANMADD's Avatar
bapapp15,
Trailer cars.........Been there ...my current motor has reduced compression and cam.
MKS427 and Harpoon PV2 like this.
Tags
331 stroker, autocross, help needed, high rpm, road racing
