04-22-2003, 08:26 AM
CA
Cobra Make, Engine: A Blue Car
Originally posted by Jack Zupan
Rick,
I think the problem is that the Windsor and the Cleveland have different deck heights. If I remember correctly the Windsor is taller by about 0.3 inches. This will throw your header geometry way off by the time you get to the chassis frame. I had a Cobra like this until last year and the headers were custom made. You may have to do that also. If I can dig out any help from my old notes, I will let you know.
Jack Z.
Jack,
The deck height has nothing to do with it. The heads are completely different, especially the exhaut ports which are almost 1" longer and angle much further down than a windsor. If you are curious, look at the difference side by side sometime. The differences are very obvious. The header bolts aren't even in the same configuration. I learned a lot about the cleveland style head when I first moched up my motor in my car and the heads banged against the upper frame rail. They are huge compared to the in-line valve windsor head.
Most small block folks stay clear of the canted-valve stuff ie, cleveland, boss, c-3 and yates.
John Marsey
NASA - Instructor - 2012 TTA Champion - We Drive Harder!
